Aerostar Ford Aerostar
intermittent heater blower problem
Old Feb 18, 2007 | 12:31 AM
frabax1943's Avatar
frabax1943
Hi
I have a heater blower problem on my 1997 Aerostar~the blower does not operate at times. The motor test ok and the fuse is good. If I remove the fuse and put it back, the blower will operate for a while until I hit a bump in the road then it will cut out, hit another bump sometimes it will start up again. It's the same thing if I bang the dash, or wiring under the hood. It's an intermittent problem, but where to start checking?
It's -30c to -35c up here these days so the fan switch gets a good workout.
Old Feb 18, 2007 | 12:48 AM
xlt4wd90's Avatar
xlt4wd90
If you can get it to pop on with a thump to the dash, it's a good chance the fan switch is the problem. Does it work better after you flip the switch through its positions a couple of times?
Old Feb 18, 2007 | 09:28 AM
96_4wdr's Avatar
96_4wdr
Ford in the 90's is not know for quality long life switches.
the fan switch carries a heavy current load
Old Feb 18, 2007 | 09:32 AM
frabax1943's Avatar
frabax1943
Thanks, I'm very sure it's the switch~but I'm not crazy about pulling the dash apart in the dead of winter.
Old Feb 18, 2007 | 09:37 AM
frabax1943's Avatar
frabax1943
Sometimes it does, I believe your right~it's most likely the fan switch~~I guess I'm going to have to bite the bullet and pull the dash apart.
Thanks
Frank
Old Feb 18, 2007 | 11:30 AM
copper_90680's Avatar
copper_90680
Hi Frank:
Welcome to our FTE forum
Old Feb 18, 2007 | 11:59 AM
frabax1943's Avatar
frabax1943
Thank you
Frank
bismic
Aug 10, 2015 10:35 AM
nofx guy
15
Aug 22, 2012 07:37 PM
RANGER589
18
Jun 3, 2011 10:03 AM
kawa
May 17, 2010 07:57 PM
falconerr68
New Member Introductions
May 21, 2006 06:34 AM
