Rear axle thrust
Old Feb 17, 2007 | 06:13 PM
whooboy's Avatar
whooboy
Rear axle thrust
Does anyone have an idea as to what the rear axle thrust is supposed to be? I have a '98 4x4. I changed the rear brake pads yesterday and noticed that I have quite a bit of thrust on both axles. I'd say greater than 1/8 inch. Is this normal? No noise, no leaks.
Thanks
Old Feb 18, 2007 | 08:26 AM
steve(ill)'s Avatar
steve(ill)
i believe the explorer is the old sytle alxe. has straight roller bearings on the outside and pushes into splines in the bevel gear set. there is a retaining c-clip that holds the axle into the bevel gear set. moving back and forth up to 1/8 inch wuold not be uncommon.
Old Feb 18, 2007 | 09:58 AM
Flash635's Avatar
Flash635
Steve (ill) is right.
My right axle moves a bit more than 1/8th inch and sometimes the flange scrapes on the brake backing plate.
Very annoying and I can't see how to stop it.
Old Mar 19, 2007 | 08:53 AM
vaquero32's Avatar
vaquero32
there is every possibility that your axle's gears inside are cut a slight bit deeper than others.
Old Mar 19, 2007 | 11:51 AM
mrshorty's Avatar
mrshorty
If Flash635 is still monitoring this, it seems like I have heard of rare cases where those aforementioned C-clips wear a little and become too thin, which could allow the axleshaft to have excessive play. If there are no problems at the outer end of the axleshaft, it might be worth the effort to open the differential, take the crosspin out, and inspect the C-clips.
RiceBiker
Sep 29, 2014 10:06 PM
wrdabney
Apr 6, 2013 09:16 PM
jmczzz
Apr 27, 2011 09:53 PM
abn
Jul 6, 2009 01:02 PM
