Sponsored by: Real Truck
Upfitter Switches
Old Feb 17, 2007 | 01:58 PM
davidwruth's Avatar
davidwruth
Upfitter Switches
Does anyone know if the upfitter switches can be made into a momentary switch?
Old Feb 17, 2007 | 02:13 PM
Bear Hunter's Avatar
Bear Hunter
Not sure what you mean...do you mean like flipping it on and off?
Old Feb 17, 2007 | 09:16 PM
6L PWR's Avatar
6L PWR
Yes, I read that in a tech forum somewhere.
Old Feb 17, 2007 | 09:19 PM
F250tuff's Avatar
F250tuff
Yes, there was a post (like a year ago) on here where someone told how to take one apart and put a spring in it, so that it returns to the off position when you take your finger off of it. It may take a while to find it using the search function, but you should be able to find it.
Old Feb 17, 2007 | 09:37 PM
6L PWR's Avatar
6L PWR
Found the instructions. Here you go:
Converting to momentary switch’s
1. Snap off the outer upfitter switch bezel with a small screwdriver working from the rear.
2. Separate front half of switch panel from the circuit board using the same
technique
3. Next you will have to remove the switch paddle that you want to make
momentary, if it is switch #1 or #4, working from the front of switch gently spread the plastic at the pivot and remove the switch, if you want to do Switch #2 or 3, I think you will have to remove the outer paddle first to make room although I did not try this.
5. Once the switch is apart if you look at the backside of the paddle you will see a white plastic rod that is spring loaded, now look into the housing cavity and you will see this
http://img217.imageshack.us/img217/6...fitter23gh.jpg
6. I used a small piece of an oil bottle and glued it into place like this
http://img217.imageshack.us/img217/6...fitter37wg.jpg
7. All you want to do is cover the lower dent so that the plastic rod does not have a place to snap into
8. Now just reassemble the pod and it should be momentary
Old Feb 18, 2007 | 05:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to SD...enjoy.
Jhndere
Dec 22, 2016 11:42 AM
bigcountry1009
Oct 27, 2014 05:09 AM
mlbmd
Apr 2, 2009 09:55 PM
Froglips
Sep 14, 2008 08:23 PM
captkrunch
Jun 23, 2006 07:02 AM
