tow haul problem
Old Feb 16, 2007 | 11:42 PM
Robert porovich's Avatar
Robert porovich
tow haul problem
My friend has a 04 6.o with an 04 engine and the truck turns off the tow haul when pulling his 11,000lb 5th wheel trailer up steep grades he says it drop,s to 1000rpm,s.Dealer changed wire harnes but it still does it.
Old Feb 17, 2007 | 10:22 AM
firesoutmatt's Avatar
firesoutmatt
The Tow /Haul is designed to hold the gear longer and keep RPM's highier.
When you hit the brake it will drop a gear and hold RPM's .
So if he's turning it off it will drop RPM's .
Not sure of what your asking ??
Old Feb 17, 2007 | 10:57 PM
Robert porovich
It turns off without him turning it off
Old Feb 18, 2007 | 11:15 AM
firesoutmatt
Ohhhhhhhh Now I get it.
I don't have an answer for that one other than see the dealer.
Old Feb 18, 2007 | 08:31 PM
toolman05kr's Avatar
toolman05kr
Check the button on the shift lever. I have changed several of these for that same problem and this has always fixed it
Old Feb 18, 2007 | 08:48 PM
06PSD&79460's Avatar
06PSD&79460
has anyone experienced hard shift when turning tow/haul on. seems like when rolling slowly and turning it on my trucks jolts as if it doesnt like being engaged. should i take it to the dealer? i only have 6k miles on it. engaging at higher speeds is no problem. i dont understand?
Old Feb 18, 2007 | 09:25 PM
Btravelen's Avatar
Btravelen
I had this happen once, but I don't usually turn it on at that time. I either turn it on and leave it on, or when I begin to slow down, for the braking effect.
Old Feb 19, 2007 | 04:51 AM
npccpartsman's Avatar
npccpartsman
towhaul does change the tranny shifting strategy. Shifts are firmer and sooner down shifting and later up shifting. You really shouldn't notice any difference when engaging it unless you're doing it at really low speeds and the tranny downshifts because it thinks you're towing something. If you think you have a problem, find someone who has a similar truck and ask them or get them to drive it and see or take it back to the dealership and ask them to test drive it. I personally don't think you have a problem by the way you describe it.
Old Feb 19, 2007 | 06:05 PM
18vtx00's Avatar
18vtx00
Sounds about normal as you have it described, but you are also hearing it second hand.. and sometimes the story changes.. Have your buddy get on FTE and set up a SC..
jdedwards7676
Feb 12, 2013 05:15 PM
xsportplyer
Mar 1, 2012 07:51 PM
2012 SD Snowbuster
All Things Towing
May 31, 2008 12:54 PM
jtharvey
52
Jul 28, 2006 03:19 AM
jpeckinp
All Things Towing
13
Jan 20, 2005 06:59 PM
