U-haul Brakes?
Old Jan 15, 2005 | 10:37 PM
jpeckinp's Avatar
jpeckinp
U-haul Brakes?
Are the brakes on a U-haul car carrier used while towing or are they only for safety puposes? Like if the trailer disconnects.
Here is the reason I ask.
I have to tow my wifes car through the Rockies and I want to put as little strain on my truck brakes as possible. I was thinking of using a tow dolly but the car weighs more than the max FWD of 3400lbs for the U-haul and the tires are too big for using the Penske tow dolly max is 16" and I have 17". So I have to use the trailer that weighs 2k and the car weighs 3600 for a total of 5600.
I have a '04 F250 CC V-10 with 3.73's so I know I can get up the mountains just fine but the coming down part is what I question. I sure would like it if the brakes on the trailer were active to help with the normal braking.
It sure would be nice if U-haul had a trailer with electric brakes.
Old Jan 15, 2005 | 10:59 PM
believer45's Avatar
believer45
U-Haul uses surge brakes on their trailers that have brakes. I believe the open car haulers have brakes. Surge brakes actually work pretty well in normal conditions but do not give you the option to use trailer brakes only in a sway situation. They also need "locked out" to back up.
They work by using the force of the trailer tongue pushing against the hitch (and therefore the back of the tow vehicle) to apply hydraulic brakes. I have towed many times with no problems.
They should work fine for you in the situation you describe.
Dave / Believer45
Old Jan 15, 2005 | 11:43 PM
Eric C.'s Avatar
Eric C.
Only the early surge brake systems needed to be LOCKED OUT. A properly adjusted surge brake uses momentum and the weight of the towed load to apply hydraulic pressure to the brakes. Hence you can back up as long as it's not up hill or to fast. As far as renting a trailer for pulling a vehicle cross country they're fine but take a good look at things like safety the coupler, chains, the wheel straps, and latches for the ramps. I used to work for them and did a lot of road calls because some one rented one that should have been sent in for repair.
Old Jan 16, 2005 | 01:06 AM
Steina's Avatar
Steina
CO River Rat
The only problem you might have is on long, steep downgrades; you could end up at the bottom with fried trailer brakes from the trailer pushing the tow vehicle. Don't know if U-Haul will tell you, but it wouldn't hurt to ask when the trailer's brakes were serviced/adjusted. Good luck on your trip!
Steve
Old Jan 16, 2005 | 01:46 AM
ford390gashog's Avatar
ford390gashog
as long as going down hill you use low gear the f-250 should be able to stop it
Old Jan 16, 2005 | 05:58 AM
blackf3504dr's Avatar
blackf3504dr
Good point ! I worked at an RV dealer that also rented U Hauls and I couldn't believe some of the junk that people turned into us ! Some with dangerous safty issues that the renting dealer didn't choose to address and just "passed" it off to someone else ! Some times it takes a couple of weeks for U Haul to get to the piece of equipment on your lot that needs repair , sooo instead of waiting to get something fixed the dealer will rent it to make the commission and at the same time let another dealer get it fixed . Just check out the trailer before you leave the lot , make sure all the lights work ( it's THIER job ! ) and tires are in good condition and the ramps work as they should . Also note any damage you see , the dealers are pretty good about spoting damage but double check what they have marked on the contract you sign BEFORE you leave the lot . Have a good trip !
Old Jan 16, 2005 | 10:02 AM
tsc's Avatar
tsc
Sorry to stray off topic.
But how do you "lock-out" the surge brakes? I rented a U-haul trailer (8'X12") and it had surge brakes. The dealer was a 900 Year old woman, who knew nothing. I had to back up a hill, and the brakes just locked right up.
Old Jan 16, 2005 | 12:42 PM
blackf3504dr
Some have a pin you insert to keep the coupler from moveing and others have a lever you turn and you can even get one with a solonoid to lock them out without leaving the cab .
Old Jan 16, 2005 | 02:20 PM
me1mckee's Avatar
me1mckee
I used a 8 x 12 uhaul to move cross country and pulled it with a 96 S-10, 4x4 v-6, manual trans. Gross weight was 9000 lbs and I know it was WAY over what I should have towed with that little truck, but I had to move and didn't have the money to make choices. Bottom line: I came across the High Rockies through Wyoming, Idaho, and Colorado. I used the same gear going down that I used going up, usually 3rd sadly and did not have any problems with smoking brakes, never even got them to stinkin. The two trailer use the same brake systems, so you'll be fine, just be smart. Mat
Old Jan 16, 2005 | 11:08 PM
Eric C.'s Avatar
Eric C.
That's the sum of all of it. Especialy watch your speed. They don't post the reduced speeds for trucks and vehicles pulling trailers for nothing. I do a lot of towing with my truck due to work and I see a lot of people overdriving (to heavy or just way to fast) hence a lot of wrecks out there, especially during snow and cold weather. If it starts to feel lose just slow down about 5 mph and just be carefull.
Old Jan 17, 2005 | 08:19 PM
jpeckinp's Avatar
jpeckinp
The good thing it will be warm out when we make this drive. It should be during the summer. Thanks guys for all the info.
Old Jan 18, 2005 | 05:04 AM
blackf3504dr
You could also check with Budget truck rental I think they have car trailers too . Make your reservation early then follow up with a phone call the day before you pick it up to make sure they have one . We sometimes had trouble getting car trailers ( popular ) and it's not a pretty site when you have to tell the customer you don't have the trailer they reserved !!! Oh , one more thing .... Go on line and see where the best deal is , U Haul dealers are told to match or beat anybodys written quote ( within reason ) , so may save a few $$$
Old Jan 20, 2005 | 10:59 AM
SAlexander's Avatar
SAlexander
Exclamation
I've rented a few U-Haul trailers. The car hauler and the Enclosed 6X12. Some of them were better than others. One of them had AWSOME brakes another I think had none. They are disc brakes so if they are in order they're very effective. You do have to make sure that everything is working before you leave the renter's yard. Always check the lights, coupler, and tire pressure. I was rented a trailer with a flat tire and had to wait a few hours for the U-Hual service truck to replace it at the renter's yard because the rental agent didn't want to be bothered. One time I rented a car hauler, the dealer hooked up the hitch while I checked the lights. After driving about 10 miles the trailer got much noisier and the ride changed. I stopped to check things out and discovered that the coupler had openned and the trailer was dragging on the ground by the safety chains!! The UHual trailers are handy and a bargain, BUT be careful and make sure they're not giving you junk!
Old Jan 20, 2005 | 06:59 PM
blackf3504dr
Unless it is a U Haul Center the dealer is not allowed to change tires on U Haul equipment , the only thing a dealer can change is light bulbs so it's not that the dealer didn't want to be bothered . And like everything , U Haul dealers have the same "worker Pool" to hire from sooo ....... Check and double check everything yourself before you go out the gate !
Gary Lewis
240
Jan 21, 2017 08:26 AM
Modding4MPG
All Things Towing
Aug 20, 2015 06:43 AM
Mdc9966
21
Jun 14, 2015 11:28 PM
DPDISXR4Ti
22
Dec 20, 2012 08:57 AM
speedsauto
Mar 12, 2003 03:52 PM
