turbo upgrade
Old Feb 16, 2007 | 08:46 PM
ncfirefighter46's Avatar
ncfirefighter46
Question turbo upgrade
where can i get a up grade for my turbo to change it to a 3 incher? i have looked around and all i get is for PS diesels? i would settle for a used one in good shape
Old Feb 16, 2007 | 09:09 PM
Mr. Bob's Avatar
Mr. Bob
I believe the part # you are looking for is ATS: T730442OH
check out the ATS site directly for more info
www.atsdiesel.com
Old Feb 16, 2007 | 10:28 PM
deanj's Avatar
deanj
ATS is the only company that makes the 3 inch outlet housing for the garret turbo (ats designed the system for ford, then ford screwed it up). Other companies made a 3 inch down pipe that bolted up (clamped up) to the 2 1/4 outlet housing but I am not sure if thier are still available. If you are thinking of doing the mod, get the outlet and 3 inch down pipe (check around the web for companies that sell - may get a better $ than ats), then get a 4 inch exhaust for a 94 1/2 powerchoke (with or without muffler). Now look at mod's to your intake, either ram air (home built) or cowl air (hypermax). Then install your guages (pyro, boost etc.). Now you can turn up your pump and increase your boost.
clean concepts
Aug 2, 2012 07:02 PM
FarmBoyFords
13
Dec 15, 2011 06:49 PM
turbo diesel fan
18
Oct 6, 2010 02:22 PM
Jeremy2792
Nov 24, 2009 09:21 PM
jayzeller79
Mar 1, 2008 08:22 AM
