dieseling and run-on
Since this thread died a while back and was then resurrected, I don't see any problem with me hijacking it.
How does timing affect "dieseling"? Once the key is shut off, there is no spark, and therefore, timing has no effect...at least it shouldn't in my mind.
Would someone like to expound on this subject? How can spark timing affect dieseling if there is no spark to be timed?
If timing is such that you are getting an incomplete burn and eventually building carbon in the CC, I suppose that would contribute.
Hot spots, wrong plugs, wrong idle setting, pooling in the manifold, plus deposits might be contributors. Poor CC design with the sunken pistons will contribute when other things conspire with them.
I think my problem however, is caused by a leaking intake manifold, which is causing oil to be pulled into the intake tract, causing carbon deposits in the CC.
fordkid122
03-22-2016 03:32 PM
The_Josh_Bear
12-16-2014 11:01 PM
Im50fast
32
09-23-2014 05:47 PM
