302 Performance Build
Old Nov 7, 2013 | 11:06 AM
olblue77's Avatar
olblue77
So my 302 in my truck right now is shot. Oil pump is going out and piston seals are gone. It is stalling whenever i come to a stop and its hard to start and keep started once its in gear. Its eating up so much oil and so much of my money that I'm going to tear it apart and rebuild. So far for performance upgrades I'm wanting to put the Edelbrock 5435 dual intake manifold with two Edelbrock 500cfm Performer carbs. I've had a few people cringe whenever i say that. I also want to put a Comp Muthr Thumpr Camshaft in it. Everything else that needs replacing will be stock or stock replacement. Anyone who thinks I need to do something more or change up this combination, your opinion is welcome. Any advice is more than appreciated. I am not a moron when it comes to engines but this is the first time I have pulled an engine and completely rebuilt it so I need SOME guidance. Thanks.
Old Nov 7, 2013 | 11:07 AM
olblue77's Avatar
olblue77
Also what the heck is a girdle?
Old Nov 7, 2013 | 01:27 PM
85e150's Avatar
85e150
I take it this is your 1977 truck motor.
Read on here, post 3:
https://www.ford-trucks.com/forums/1...02-advice.html
You will not get "performance" out of the low compression that engine had as OEM, so you need heads and different pistons.
Your cam will have no low end and needs higher compression to make any power. What gears and trans do you have?
A girdle is a device bolted to the main bearings and elsewhere in the bottom end of an engine to strengthen it for higher power/rpm running.
M-6340-A302 Mustang Main Cap Girdle 289/302 | CJ Pony Parts
Attention to rods, rod bolts, valve springs and anything related in the valve train will take you to 7000 rpms with a 302. If you want to spin it harder than that, you will be spending more. The 302 block does not live long over 400 horse.
Old Nov 7, 2013 | 05:40 PM
olblue77's Avatar
olblue77
The transmission is a c4 that was rebuilt for a 600hp 351 windsor. not sure what gearing is in it though
Old Nov 9, 2013 | 01:05 AM
SDDL-UP's Avatar
SDDL-UP
ol'blue77
Sounds like you want your engine to look cool - and that's okay, just don't complain about the lackluster "performance" of that setup.
A "girdle" is probably referring to a stud girdle - main bearing caps or rocker arms on a 302. They are used to tie everything together to help maintain stability at high RPM's - you will not need this with your setup.
Old Jan 10, 2014 | 06:33 PM
Mrschulz's Avatar
Mrschulz
My truck had 130,000 on it and it just dosent seem to run. When I start it, I start it it turns over runs with almost no power for 2 seconds than has power. I've put headers on no leaks new air filter plugs wires dist cap etc
Anyway what I'm planning to do is pick up another 302 and build it. Kinda looking like this sexy thing :
http://quadcities.craigslist.org/pts/4274012030.html
Old Jan 28, 2014 | 09:00 AM
ford347stroker's Avatar
ford347stroker
im looking to install a b303 cam in my 302 will it work with everything stock? or will I need longer or shorter push rods or what?
Old Jan 28, 2014 | 05:18 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Does it have the factory roller cam set-up now?
Old Jan 28, 2014 | 05:30 PM
BaronVonAutomatc
Unless you're building a mud racing truck that cam/intake is a poor choice. Especially on an otherwise stock engine.
If you're determined to use those parts and your intention is not to just leave it idling with the hood open you'll need to turn the engine 6,500+ rpm to appreciate them. Which means new heads on top of a full rebuild with hyper/forged pistons and a complete balance job. And a new valvetrain. And probably some 5.13 gears to back it up. I'd guess maybe $7,500 once it's all said and done.
I'd build a 350hp/450tq 347 I was going to drop that kind of dough but that's just me.
Old Jan 28, 2014 | 05:42 PM
BaronVonAutomatc
I'm reminded of the expression, "couldn't pull a sick ***** (prostitute) off the pot".
Old Mar 4, 2014 | 02:58 PM
olblue77's Avatar
olblue77
So I have done a little more research on the 302. Going with Edelbrock performer intake manifold with a edelbrock performer carb. All new lifters, springs, rocker arms, and lifting rods, comp ***** thumpr camshaft, all new timing set, high volume oil pump, water pump, new distributor and cap (not that distributors have anything to do with building power, mines just messed up) new long tube hedman hedders and exhaust system. Changing rear end from 2.62 to 3.73 gear ratio. Is it essential to get new heads to get a camshaft to perform better? If I get new heads does ford make performance heads?
Old Mar 4, 2014 | 07:19 PM
BaronVonAutomatc
To take advantage of that cam new heads would be a must. Ford makes some okay aluminum heads but you can get better for about the same money.
And if you're changing gears anyway go to at least 4.11. What size tires?
FWIW, I've got a 331 in a Mustang with the Comp 292h cam, air gap intake, 750 dp backed up by a 5-speed and 3.73 gears. Roughly the same combo you're talking about for your truck, albeit with with smaller tires in a vehicle that weighs at least 1,000 pounds less and it's still lazy off idle. Lazy enough I'm changing the cam so it's more comfortable to drive around the city.
You'll need at least new heads, a full rebuild, full balance job, pistons to raise compression to ~10.5:1 if you want it to run at all like it should with that cam.
Old Mar 4, 2014 | 08:31 PM
olblue77's Avatar
olblue77
You'll need at least new heads, a full rebalance job, pistons to raise compression to ~10.5:1 if you want it to run at all like it should with that cam.
My tires are 30x9.5 my drag racing buddy told me to gear the rear end at 3.73 but he's a little dinky so I think ill do a little research before I choose his advice over yours. Edelbrock heads are good? I'm more concerned about cracking the block. It seems like everything I need to make the camshaft work is going to put out too much hp and crack the block. I might decided to go to the scrap yard and pull a 351w for my truck.
Old Mar 5, 2014 | 04:46 PM
BaronVonAutomatc
A stock 5.0 block is probably good for 500+hp so cracking one isn't a big worry.
While a 351W is a much better truck engine than a 5.0 it's not going to be a whole lot more resistant to cracking. A roller 351 would be a nice upgrade.
Regardless, you should give up on that cam until you've got a nice, light muscle car to drop it in. An otherwise identical truck with something like a 268h cam would run circles around you. Unless you're taking it to the track regularly. Even then it would probably still beat you in a 1/4 mile.
I understand the appeal of a choppy idle, but a choppy dog just isn't my idea of fun.
Old Mar 5, 2014 | 06:37 PM
olblue77's Avatar
olblue77
Ive heard that 302's do not last long after 400hp. (it's a windsor not a coyote). I have decided to do the 351w build with some gt40p heads just because. I couldn't care about a choppy idle. To me it makes no difference. What cam would you prefer? Any more suggestions? You seem to know what you're talking about.
72explorer
Nov 17, 2014 08:59 AM
deve
100
Jul 28, 2010 08:22 PM
Ravin
37
Dec 10, 2003 09:38 AM
mustangman66cpe
Oct 18, 2003 02:24 AM
gamehunter
Jun 24, 2002 08:05 PM
