1978 - 1996 Big Bronco
headlight switch
Old Nov 11, 2002 | 08:19 PM
christop43's Avatar
christop43
headlight switch
How hard is it to replace the headlight switch on a 90 Bronco? The headlights work fine, but the instrument panel dimmer crapped out so I have 2 settings- bright or off. I figured I would do this since I just ordered white faced guages.
Old Nov 11, 2002 | 09:47 PM
fcarruth's Avatar
fcarruth
headlight switch
Actually it is pretty easy. Just remove a half dozen or so screws from the dash area. I think that you will actually only have to remove the right side lower panel that has the 4X4 switches (if auto lock)and then remove 1 screw that holds the left side on. The rest of the panel is removed by prying it from the dash with your fingers or a small screw driver. I just replaced a few bulbs on my 89 and it was easy to remove the entire dashboard.
Good luck to you.
Frank
1989 EB Bronco w/302
230,000 miles
Old Nov 12, 2002 | 04:25 PM
christop43's Avatar
christop43
headlight switch
Well I got the lower left pannel off where the headlight switch, wipers, and rear window defrost are. Then I unscrewed a metal bracket that holds the healight and wiper switches to the dash. Now my problem is on the metal bracket the headlight switch is held in place by a nut, but I can't figure out how to take that nut off. It is not as wide as your standard nut so if I put a wrench on it I will strip it. What do I do? If I do use a wrench to take it off does anyone know the size? I am thinking that it is metric
Old Nov 12, 2002 | 07:02 PM
christop43's Avatar
christop43
headlight switch
Disregard the last post I made, I fixed it kinda. I got the headlight switch replaced, but the new one doesn't work right. The dome light will come on before it clicks when turned all the way to the left (I can picture a dead battery). So I will return it and get another new one.
Old Nov 14, 2002 | 08:53 PM
ford racer 02's Avatar
ford racer 02
headlight switch
Ya i was wondering where you got your white face gauges at is there a retailer or something to ghet them from?? let me know
Old Nov 14, 2002 | 09:14 PM
christop43's Avatar
christop43
headlight switch
[updated:LAST EDITED ON 14-Nov-02 AT 10:50 PM (EST)]I ordered them a couple of days ago so they are not here yet, but I got them from http://www.procarparts.com/ They have three different guages for the 87-91 truck.
http://www.procarparts.com/store/displaydetails.cfm?pid=FD-F150-8791-SIG-T2
http://www.procarparts.com/store/displaydetails.cfm?pid=FD-F150-8791-RIG-WT
http://www.procarparts.com/store/displaydetails.cfm?pid=FRD-EXD-8791-WTGW-XXNR-RVGX
Maybe Ken could start carying these in his online store???
Old Nov 14, 2002 | 11:55 PM
Riso79's Avatar
Riso79
headlight switch
mustangpt
Apr 22, 2015 09:59 PM
53FOPAR
Feb 2, 2013 08:34 PM
dmp1983
Nov 4, 2012 11:28 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
STiNGeRX
1983 - 2012 Ranger & B-Series
Jun 8, 2001 10:06 PM
