1978 - 1996 Big Bronco
4" to 6" radius arm brackets
Old Nov 12, 2002 | 09:04 AM
90EBBronco's Avatar
90EBBronco
I currently have a rough country 4" suspension lift and want to increase to 6". All the brackets came with 4 and 6 inch holes in them except the radius arm brackets. If I increase the lift will I need to get new radius arm brackets? I already have the new blocks for the back and am looking at coil spring lifters for the front instead of getting new springs. Anyone have any experience with these? Other than that what else will I need to do to complete this new lift?
KJ
Old Nov 12, 2002 | 09:15 AM
adelyser's Avatar
adelyser
You will need the 6" radius arm drop brackets, or an extended radius arm conversion kit. If you don't use the 6" brackets, your castor will be off and your steering will seem to be much more squirrely.
Old Nov 12, 2002 | 09:35 AM
90EBBronco's Avatar
90EBBronco
Can I manufacture 2" steel plates to put between my 4" brackets and the frame? That seems logical and easy to do and it would drop the brackets the 2" that I need. What about my driveshafts? Will they need to be lengthened?
KJ
Old Nov 12, 2002 | 07:40 PM
88B_RONC's Avatar
88B_RONC
[updated:LAST EDITED ON 12-Nov-02 AT 08:42 PM (EST)]You might run into some strength issues if you just try to add another block between your bracket and the frame...but thats just my 2 cents.
As for your driveshafts, my friend put a 6in lift on his 94 and he didn't need to lengthen his.
Old Nov 14, 2002 | 11:57 PM
Riso79's Avatar
Riso79
Why not just get some new radius arms? The look much better and will help the truck from looking like it has big drop-down brackets everywhere.
Old Nov 15, 2002 | 06:53 AM
90EBBronco's Avatar
90EBBronco
Because I would like to not have to spend $300+ for two more inches.
KJ
Old Nov 15, 2002 | 12:21 PM
greystreak92's Avatar
greystreak92
MY FYN 79
Oct 18, 2015 04:13 PM
AvdDrift
Dec 18, 2014 10:04 AM
NW 150
Sep 29, 2012 08:18 PM
btravis90
Feb 15, 2012 12:17 PM
alexjp91
Mar 16, 2008 05:38 PM
