Sponsored by: Kumho
radius arm drop brackets?
Old Mar 16, 2008 | 12:01 AM
alexjp91's Avatar
alexjp91
i am thinking about lifting my truck. i want to get 3in add-a-leafs plus the 3 in blocks i have alreadyy and 6" lift coils. i know ill need a drop pitman arm and probably extended brake lines, but do i need radius arm drop brackets or i-beam drop brackets?
im trying to do this on a budget and so far i can get the coils and add-a-leafs for only $200
Old Mar 16, 2008 | 12:08 AM
khadma's Avatar
khadma
Carpenter Local 745
As I read your post, you have a 3in add a leaf and a 3in block to provide the rear lift and you have 6in longer coils for the front. Correct?
You will need to lower the TTB pivot points in the front. Left and right axle pivot mounts and the two radius arm brackets.
Try looking on ebay for these items, but most complete kits run from 450 to 1200. The less expensive kits maybe the way to go if you can not locate the individual parts.
Check the FTE classifieds too.
Old Mar 16, 2008 | 08:13 AM
alexjp91's Avatar
alexjp91
what do the pivot mounts do? cause i couldnt find them on ebay or summitracing. i found a kit on broncograveyard that has the pivot mounts and radius drop brackets but its $290. so are these an absolute necessity?
Old Mar 16, 2008 | 12:48 PM
khadma's Avatar
khadma
Carpenter Local 745
It will keep proper steering and suspension geometry with a big 6 inch lift like the one you want to install, so yes you need the R and L axle pivot brackets for a TTB suspension.
Please list you truck info - yr, model, etc.
Old Mar 16, 2008 | 05:38 PM
alexjp91's Avatar
alexjp91
its an 83 f150 4wd. what is the cheapest 6" lift? ive found a tuff country for 500.
Ron94150
Sep 2, 2015 06:41 AM
Jacob Bush
Aug 6, 2015 02:27 PM
jbravata2
Mar 20, 2014 07:28 PM
HillbillyDeluxe81
Ford Truck Parts for Sale
13
Jan 20, 2014 11:01 AM
93f250tn
17
Nov 4, 2013 09:22 PM
