Sponsored by: Real Truck
Battery indicator light is ON
Old Feb 14, 2007 | 11:26 PM
cobaum's Avatar
cobaum
Anybody had this problem? The manual just says it's a charging system problem.
Old Feb 15, 2007 | 01:09 AM
tvsjr's Avatar
tvsjr
Sure... could be a toasted alternator, bad battery, all sorts of things.
Old Feb 15, 2007 | 03:22 AM
repou's Avatar
repou
Yeah I would have to say most commonly it is the alternator but I have also seen a problem with one of the wires on the back of the alternator coming loose in the connector. My old 2000 f350 psd went through 7 or 8 alternators
Old Feb 20, 2007 | 09:38 AM
not88's Avatar
not88
Just went through this on my 99, replaced the alternator still had the problem, checked all connectors, they looked good, then replaced with another alternator and the problem was resolved. The first replacement alternator was charging, but the battery light was still on, the problem with the first replacement alternator must have been in the internal sensor circuits. I guess rebuilt alternators have a high failure rate out of the box.
to check where the problem is
1. check voltage with truck running at the batteries, if it is a diesel wait until the glow plugs shut off, should have higher than 14 volt if not replace alt
2. if charging is ok check voltage on the connector on top of the alt
left wire should be 12 v if not check wiring to the connector
right wire should be approx 1.5 with key on engine not running and 12v with engine running if no 1.5v check wiring to connector, if no 12v while running bad alternator
3. if you do not get 12 v to the left connector check fuse 7 under the hood, it is a 10amp fuse
to test the connector it must be plugged into the alt, just push your meter probes into the top of the connector
good luck
Old Feb 20, 2007 | 10:30 PM
cobaum's Avatar
cobaum
It was the alternator. The diode connector was broken off in the alternator. $215 @ NAPA for one with lifetime warranty. Very easy to replace.
Old Jan 14, 2010 | 08:01 AM
f.goodell's Avatar
f.goodell
battery indicator
My 2005 Ranger (3.0) has a similar problem. Usually at 2g rpms. Got home on battery power on one occasion. Other than that the problem is sporatic. 18 miles to work. Light stays on last 5m or so @ hiway speed. Tested Alt. it draws from battery, but settles down @ 12.34 volts. T. pulley and S. belt seem to be good.
Old Jan 14, 2010 | 08:20 AM
f.goodell's Avatar
f.goodell
Makes sense not88. Will re-test. I too have bad luck w/ rebuilt alts. Went through 4 of them B4 I got a good 1. Lots of time wasted on that project.
Old Mar 26, 2014 | 10:06 AM
garththefish's Avatar
garththefish
battery light is on full time , and it is over charging main battery, corrodes up every 2-3 weeks, 2004 F350 - 6l
any ideas?
Old Mar 26, 2014 | 10:32 AM
wizkid00104's Avatar
wizkid00104
any ideas?
My guess would be the regulator. Did you take a voltage measurement at the battery with the engine running?
Just for the record, alternators can be rebuilt. Typically, there is a voltage regulator on the back and underneath that is the brush assembly. If you alternator spins true and the bearings are fine, save some cash and just replace the regulator and the brushes.
Regulator:
More Information for STANDARD MOTOR PRODUCTS VR455
Brush Assembly:
BWD Alternator Brush Set X581: Choose the best Alternator/Generator Brush Parts at Advance Auto Parts
ManfredVonRichtofen
61
May 30, 2022 05:57 PM
mustang9701
Feb 11, 2017 04:29 PM
gardnesd
May 17, 2016 03:21 PM
Vince79vette
Nov 12, 2015 06:17 PM
FE427TP
Jun 14, 2001 12:43 PM
