Sponsored by: Real Truck
Winter Ballast
Old Feb 15, 2007 | 09:41 PM
  #31
mudmaker's Avatar
mudmaker
Im not trying say securing a load is not important, but if I have a sheet of steel in the bottom of my box that sits against the front and cant slide around i would consider it secure. If I got rearend hard enough to push that plate through the entire cab I dont think I would stand a chance with or with out it there. I know the cabs are not that heavy, but I think you would have to be sitting still and rearended by a vehicle much larger than you to fold up the entire rear frame of your pickup! I could see it if the plate was at the back and could slide ahead, but a 4x8 sheet would not have enough room to move in an emergency breaking situation.
Old Feb 15, 2007 | 09:54 PM
  #32
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by biervergnugen
The idea of moving the weight back to the tailgate has been swimming around my head most of the morning.
What happens is it takes weight off the front-end. With a diesel, that might not be such a big deal.
With my V10, a Supercab, and a short bed, putting a lot of weight behind the rear axle (and not over it) makes it VERY squirrelly!!!
It oversteers something fierce - as in, turn the wheel a little bit and it really reacts. In slippery conditions, it might be just me, but it's better to head-on into something than spin out every time you turn the wheel a little too much.
I'd definitely test out whatever you're doing in a safe, secure place - like a parking lot ... and see what happens when you turn the wheel fast while cruising...
Oh, and ALWAYS secure your load! Strap it down, whatever you can do, but if you flip it, you don't want all that stuff going through someone elses windshield, do you?
Old Feb 15, 2007 | 11:48 PM
  #33
togie's Avatar
togie
I have a easier method it loads and unloads itself and I only get it when I need it It's called:
MY MOTHER INLAW
If weather ever gets that crapy I will pick her up and do some errands.
LOL I do love my inlaws " really"
Old Feb 16, 2007 | 05:18 AM
  #34
F-16mechanic's Avatar
F-16mechanic
Originally Posted by redford
Man, I hope not. In a fight the Marines usually band togther and the USAF runs for cover.
I gotta back Sgt Hawk, I may be in the AF now, But I started life as a Marine.......Semper FI
Old Feb 16, 2007 | 06:42 AM
  #35
redford's Avatar
redford
See what I mean!
But yes, I started life in the Army, so I know what you mean.
Old Feb 16, 2007 | 10:38 AM
  #36
biervergnugen's Avatar
biervergnugen
Hmm...That's my setup too. What were you using and how much weight was added?
Old Feb 16, 2007 | 07:20 PM
  #37
tigerman's Avatar
tigerman
My thoughts for my truck viz. a short bed 2 wd F250... ...Four sand bags @70 lbs each set against the tail gate and secured with a 2 x 6 behind the wheel well. With good tires and the rest of the tool boxes (side mounted) @about 150 lbs each the ride seems well balanced. A couple other thoughts are....1. If the weather is all that bad I would think one wouldn't be driving all that fast. 2. Some of the loads in above responses seem like overkill to me. As I get older (and already shorter), those bags get heavier every year.
BigGreenEx
All Things Towing
22
Jun 30, 2015 10:23 AM
Pillsbury
Large Truck
Jun 8, 2015 07:46 AM
automaticj5
Oct 22, 2013 09:49 PM
youngkandk
2004 - 2008 F150
Apr 20, 2011 05:31 AM
Fordtruck350
Dec 22, 2004 06:10 AM
