Sponsored by: Real Truck
Winter Ballast
Old Feb 15, 2007 | 12:43 PM
HeavyAssault's Avatar
HeavyAssault
I get a kiddie pool, throw it in the back and fill it up with water. Temps freeze the water and presto solid weight. When it warms up and I don't need it I just dump it out.
Old Feb 15, 2007 | 01:40 PM
sgthawkusmc's Avatar
sgthawkusmc
I was thinking about using plate steel. I wanted to put a piece like what they use in road construction to cover up a working hole for the night. Then I could throw my bed mat over it. I think it's something like $2/lb now though. Fisher recommends 600 lbs for my truck, so $1,200 just isn't happening. I just don't want to use blocks, sand, cement, ice etc because I actually use the bed of my truck and I don't feel like humping all that in and out when I need it...
Old Feb 15, 2007 | 01:52 PM
mudmaker's Avatar
mudmaker
Originally Posted by redford
I'd sure hate to see what would happen if you ever got in a serious accident with that much steel loose in your bed.
I really dont think it would cause much of a problem. if you were worried about i suppose you could bolt it down.
Old Feb 15, 2007 | 02:00 PM
biervergnugen's Avatar
biervergnugen
That is exactly my predicament. The buckets have proven pretty easy to get in and out (about 5 minutes to remove or install everything). There are some large stone slabs for sale at an aggregate/sand/stone operation including some that were just a few inches thick and most were 12"x36" to 18"x48" @ $0.32 per pound. $200 wouldn't as bad as the steel, but $15 for the same weight of sand using lidded buckets I already had was hard to pass up.
Old Feb 15, 2007 | 02:04 PM
msgtg's Avatar
msgtg
Re; Winter Ballast
I used to keep buckets of dried cat litter (speedy dry will work too) instead of sand. If traction becomes a problem, open a bucket sprinkle the cat litter in the wheel path and instant traction!
Since then, I've substituted the cat litter with wild bird seed. Cat litter turns to mush when it gets wet...bird seed just continues to be wet bird seed.
The bonus is the birds love it and there's no mess to clean up!
MSgtG
92 F150 SC
03 F250 King Ranch Crew
Old Feb 15, 2007 | 02:05 PM
redford's Avatar
redford
FTE Leadership Emeritus
MSgtG
92 F150 SC
Great idea!
Old Feb 15, 2007 | 02:19 PM
redford's Avatar
redford
I hope you're kidding.
I've seen a guy beheaded because he didn't secure a front-end loader properly on a ramp truck, panic stop at 40 sent the loader bucket into the cab. Also, a teenage girl was killed a few years ago while riding in a car that hit a ditch, a 15 pound speaker in the back of the car flew forward and hit her in the head.
600 pounds of 3/4 sheet, sent free if the truck is rolled, could do serious damage to buildings, cars, people or anything that gets in it's way. Can you just imagine it skidding down the road at 35 MPH, or maybe even the sidewalk?
If you rearend someone with a 600 pound sheet of 3/4 inch steel loose in your bed, where do you think it is going? It will try to go though your bed wall and through your cab. You are in for a real rude shock if you think the sheet metal of the bed or the cab is thick enough to contain the sheet of 3/4 inch steel.
What ever you use for ballast, PLEASE SECURE IT.
Old Feb 15, 2007 | 02:22 PM
sgthawkusmc
It's going to go into the back of your bed unless it has somewhere to slide. Maybe if you roll you'll have a problem, but I'm not seeing it coming out otherwise.
edit: I just noticed you did say if you rolled...However, think about all the tools etc guys carry around unsecured. I don't think I'd worry much about a sheet of steel. Debatable though I suppose.
Old Feb 15, 2007 | 04:47 PM
redford's Avatar
redford
....However, think about all the tools etc guys carry around unsecured....
It scares the living crap out of me.
Old Feb 15, 2007 | 05:21 PM
F-16mechanic's Avatar
F-16mechanic
Just my two cents here. I have to agree with Redford, What ever you use, Please secure it. Just seems to me to be a responsible and prudent thing. I know most of us with the Big trucks feel bullet proof in winter weather. However there is always the "what if" factor and "that other driver" factor. Personnally I love the idea of using the bird seed. I think I will change from sand and cat litter. Thanks for the idea.
No matter what you do, do it safely, while having fun.
Old Feb 15, 2007 | 05:23 PM
F-16mechanic
Hope this doesnt turn into an services agruement......
Old Feb 15, 2007 | 06:29 PM
sgthawkusmc
What's meant to be will be...
Old Feb 15, 2007 | 06:31 PM
  #28
Lou Braun's Avatar
Lou Braun
I use 12 70# tube sand bags tied down onto a half size hardwood pallet. The pallet is a bit wider than the space between the wheel wells so it stays in position well enough. I used the rear corner tie down points for some extra security.
The pallet of sand bags was really meant to be a counterweight when the snow plow was attached but seems to work well for driving in snow. I load it when the weather looks crummy and unload it when the truck bed is needed for something else. A tractor front loader does all the hard loading and unloading work.
This might be a bit more weight than is really needed, but these SD trucks don't seem to know when they are carrying an 800#+ load.
It does smooth out the ride too.
Lou Braun
Old Feb 15, 2007 | 06:47 PM
  #29
redford's Avatar
redford
Man, I hope not. In a fight the Marines usually band togther and the USAF runs for cover.
Old Feb 15, 2007 | 07:46 PM
  #30
msgtg's Avatar
msgtg
Hey, for the record, MSgtG is USAF Ret.
Us zoomies gotta hang together! LOL!
