Clunk shifting into 2nd gear
Old Feb 14, 2007 | 06:27 PM
BigJim191's Avatar
BigJim191
Question Clunk shifting into 2nd gear
My 94 F150 XL Enforcer makes a tranny clunk shifting from 1st into 2nd gear with the clutch pressed to the floor. The only time it doesn't do it is when the revs are right down to an idle...(almost rolling to a stop). i'm not sure what the idle is because there is no tach.
It doesn't do it in any other gear...only 2nd.
The clutch was replaced almost a year ago.
Any suggestions would be appreciated.
Thanks
Old Feb 14, 2007 | 06:51 PM
lckleen11's Avatar
lckleen11
my truck also does the same thing. i have a 1995 f-150 4x4. it also pops out of reverse on occasion. i also do not know the cause of it.
Old Feb 14, 2007 | 09:45 PM
SilverSport's Avatar
SilverSport
Mine does it too .... but I don't even think about revving it before 2nd.
Old Feb 15, 2007 | 06:04 AM
low92flareside's Avatar
low92flareside
shift forks. top of the tranny. when they wear thin, it causes this kinda stuff. mine got stuck in 2nd one day because of it. lots of info on the site, do a search, but I'll give you the short and skinny...
E-brake on, shifter in neutral. remove shifter, pull back the carpet. there's an access panel, remove the 10-12 bolts and pull the panel away. it'll probably have some black adhesive holding it down. I used a putty knife to cut thru it first. be careful not to bend up the floor pan.
now you're looking at the top of the tranny. remove about 10 bolts to top cover of tranny. remove top cover of tranny carefully. flip it over, those U shaped things are your shift forks. i imagine your 1-2 shift fork is shot. while its apart, wouldn't hurt to do the others.
Old Feb 15, 2007 | 11:53 AM
bocephus_3349's Avatar
bocephus_3349
Where do you buy the replacement parts. Do you go through ford its self or just any old parts store. Is it a pretty easy job to do?
Old Feb 15, 2007 | 01:08 PM
low92flareside
It's not too awful. Parts are probably only available at the dealership.
Old Feb 15, 2007 | 09:26 PM
SilverSport
This article goes into part of this operation, all except the forks. It is about replacing the rubber plugs on top the tranny that cause ATF leaks in our Manual Tranny, so if you are gonna do the forks, do the plugs also. https://www.ford-trucks.com/article/...e_Measure.html
I have also seen some online tranny shops selling rebuild kits that include the forks.
Old Feb 18, 2007 | 09:39 PM
BigJim191's Avatar
BigJim191
Thumbs up
Thank you very much guys you've been very helpfull!!
Old Feb 18, 2007 | 09:45 PM
BigJim191's Avatar
BigJim191
One more question...would the syncro's have anything to do with it?
or would it only be fork problems?
Thanks
Old Feb 20, 2007 | 05:54 AM
low92flareside
syncros could be the problem. i wouldn't rule it out yet. but you can get a good look at your shift forks without too much disassembly. it should be pretty obvious if the 1-2 fork has worn thin. getting to the syncros to check them out...whole new ballgame.
Oliver Herting
Aug 8, 2017 04:22 AM
Jacob Lowell
Nov 30, 2016 08:10 PM
CPB1
Nov 27, 2016 08:12 PM
jerrylynnb
1983 - 2012 Ranger & B-Series
25
Mar 10, 2012 03:50 AM
79FordBlake
13
Nov 9, 2011 05:47 PM
