1978 - 1996 Big Bronco
C6 Woes
Old Nov 15, 2002 | 04:19 AM
1988XLT2002's Avatar
1988XLT2002
C6 Woes
Old Nov 16, 2002 | 07:44 PM
gruveb's Avatar
gruveb
C6 Woes
I got home this afternoon and when I went to throw it in reverse there was an enormous clunk and thud, like I had the throttle opened.
Then I get in and drive this afternoon, no problems, until I go to put it in park and it won't go past neutral! I had to force it a little and it went in.
I came out, threw it in reverse, no problem, then tried to go to park and it was stuck again......I had to force it.
I get home, and it goes into reverse just fine, but then the clunk and thud again............
what gives?
1983 Bronco 351W with a C6
Feeding my 9 mile a gallon habit.
Old Nov 16, 2002 | 07:57 PM
Mudinyureyes's Avatar
Mudinyureyes
C6 Woes
You might want to check your linkage adjustment arm to make sure nothings come loose and make sure your bolt is in tact and secure first of all. Then check your to make sure your Transfer case shifter is slugged in the right range for 2wheel drive. Also you may want to do a finish up check on your rear yoke fo the thud noise. They can get old and worn out over time and get in need of replacement. But that is usually associated with going through your rear u-joint like they're going out of style. Hope that offers some help.
Old Nov 16, 2002 | 08:49 PM
Ford_Six's Avatar
Ford_Six
C6 Woes
Check your motor mounts, and body mounts. If these go, it can do like you are saying. Most likely it is your tranny mount.
Jared
Old Nov 16, 2002 | 10:27 PM
gruveb's Avatar
gruveb
C6 Woes
I'll give it a lookie loo!
I know I'm gonna need a new tranny sooner or later because I have a slip, but this is different entirely.
Old Nov 17, 2002 | 04:00 PM
gruveb's Avatar
gruveb
C6 Woes
Good news and bad news for me.
Turns out that the linkage was actually hitting the frame badly, right where the long link that goes from the engine compartment and connects to the linkage in the undercarriage. The little bolt was hitting the frame.
So I disconnected the pivot point that bolts to the tranny housing and had to rig it up a little bit.
Now it shifts smoothly and, well, kind of easily.
Bad news is that the housing around the steering column is broken! And further, it won't start. I'm sure that it is just because there is some little lever or something that is busted.
But I went on a day hunting and 4 wheeling trip and had to borrow my uncle's Suzuki Samuri!
I can turn the gear selector through all of the gears by hand, and I'll probably set up a starter switch under the dash or something. I'm not gonna replace the entire column piece right now if I don't have to. (Great thing about a truck is that this type of thing is acceptable.)
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
