Fixed it
Old Feb 14, 2007 | 10:46 AM
Jocaren's Avatar
Jocaren
Fixed it
Even though nobody wrote back on my post i thought i would tell you what was wrong, see what happened was the connection of the pyro,trans and voltmeter was loose so i butt spliced it and connected it back up!Next thing was the dimmer switch, my gauges werent going with the automatic headlights, i hooked up the wrong wire, instead of using the light blue wire with red stripe on the right plug(if you are facing it) i used the blue with white on the left plug..Now everything is ok and im happy i did it myself although it took me way longer than expected, but now i know and it would only be about a 1/12 job!!!
Old Feb 14, 2007 | 11:42 AM
Maxium4x4's Avatar
Maxium4x4
That was my exact thought......
Sometimes the things we do will create a problem with no answer...cause I do everything right the first time...
Old Feb 14, 2007 | 11:43 AM
Stroked Out!'s Avatar
Stroked Out!
Good For You Wiring Scares The Living Bahgbees Out Of Me!!
Old Feb 14, 2007 | 02:15 PM
Jocaren's Avatar
Jocaren
The drilling and tapping of the manifold is what scared the "BAHGEBEES" outta me, oh and the thought that my truck would burn down bcz my wires werent connected right!
Old Feb 14, 2007 | 06:18 PM
mrxlh's Avatar
mrxlh
Glad you figured it out, sometimes feels like more of a sense of accomplishment without help though.
Old Feb 14, 2007 | 07:47 PM
Jocaren's Avatar
Jocaren
ya i still have a problem though, The guages wont work unless my lights are on in either automatc mode or manual, im not sure which wires i need to connect to get them right, i wish someone could point them out or if someone is within 3hrs of albany GA that knows i will drive there tomorrow lol
Old Feb 14, 2007 | 07:54 PM
mrxlh's Avatar
mrxlh
did you check out the tech folder, I know there was a link to the Ford Body Builders site. They had the entire schematic on the site I believe.
Old Feb 15, 2007 | 07:05 AM
Jocaren's Avatar
Jocaren
that site never come up on my computer??
