Even though nobody wrote back on my post i thought i would tell you what was wrong, see what happened was the connection of the pyro,trans and voltmeter was loose so i butt spliced it and connected it back up!Next thing was the dimmer switch, my gauges werent going with the automatic headlights, i hooked up the wrong wire, instead of using the light blue wire with red stripe on the right plug(if you are facing it) i used the blue with white on the left plug..Now everything is ok and im happy i did it myself although it took me way longer than expected, but now i know and it would only be about a 1/12 job!!!
The drilling and tapping of the manifold is what scared the "BAHGEBEES" outta me, oh and the thought that my truck would burn down bcz my wires werent connected right!
ya i still have a problem though, The guages wont work unless my lights are on in either automatc mode or manual, im not sure which wires i need to connect to get them right, i wish someone could point them out or if someone is within 3hrs of albany GA that knows i will drive there tomorrow lol
