Why not to install 6" lift??
I had a 78 that I sold back in 2002. when I bought it, it already lifted 9". 6 on the suspension and 3 on the body. I cannot remember why I said I would never get/lift another bronco 6". I do not remember why I decided that. I remember the frame broke at the steering box, but I think that was more a combination of the lift and 39s. seems like something under the truck was messed up, but I can't remember.
What are the bad points of a 6" suspension lift? it may have been something I read. I plan to use the Superlift system, which will entail front and rear springs, adjustable track bar, extended lines, radius arm drop brackets, drop pitman, and bushings. I would also buy the adjustable drag link.
maybe it's the shaft angles???? don't they get too extreme with that much lift?
I'm not too worried about length. the one I had before was fine, and I'm going to use my passenger car 1330 yoke when I put the 4.10s in. it's an inch longer, so that'll take up any possible length conflict. i almost think angles aren't it, because I never crapped a u-joint.
any ideas??
any ideas??
angles are horrible w/6 and a nine inch rear the pinnion sits real low can be fixed w/ a currie high pinion 3rd and gears other than that no probs w your route the lift does lift more in the frnt but thats to level out the heavy rake these trucks had and to counter act the fact coils sag more and quicker than leaves.
must've been the shaft angles then. that's all I can seem to think it could have possibly been.i don't know why I wasso certain that i'd never own a bronco with 6" suspension lift. they also make high-angle drivelines. i'll probably just use good joints and the 1" longer pinion yoke and call it good. again, i never shat a u-joint on my other big one.
I've seen a bunch of pics of 78/79 with 4" lift and 35s. looks like too much tire.
wonder if 35x14.50 would put way more stress than 12.50 and break the frame on this one like on the one I had with 39s??
last, how long do the superlift kits take to level out? i'll just use 1" blocks until the front sags a little.
mine has a 6" skyjacker softride.the only thing i don't like is the radius arm drop brackets.they are a spacer between the bracket and the frame.i have seen other lifts that come with a 1 pc radius arm mount with drop built in to it.
as far as driveshaft angles,i put a tranny in out of a truck and it has a shorter adapter than the bronco one.the truck one was 6" and the bronco one was 9",if memory serves me.this helps both the rear angle and the front.i don't run a cv in the front shaft and the angle looks about perfect.havent broken a front driveshaft in a long time,knock on wood.
yes you can but i like the radius arms to be as parallel with the frame as possible.doesn't seem right to me with them pointing down like that,plus it pulls the axle back a little bit.
bds makes some one pc drop brackets,i just haven't gotten around to it yet.
