solonoid question
Old Feb 13, 2007 | 12:01 PM
puman's Avatar
puman
solonoid question
When referring to shift solonoids, specifically in a 4R55E/5R55E, what is meant by "inductive signature?
Old Feb 13, 2007 | 12:07 PM
Casey's Avatar
Casey
It means that the PCM can detect if the solenoid works by looking at the inductive kickback in the circuit.
If the solenoid is commanded on and there is no inductive change in the circuit the PCM can deduce that the solenoid is stuck. It then sets a code that the inductive signature for that solenoid is missing, so the tech checks for a stuck solenoid.
Old Feb 13, 2007 | 12:20 PM
puman's Avatar
puman
OK. Very good explaination. Thank you! Now the 95-96 do not use this "inductive signature", where as the 97-up do. The parts house I'm dealing with says that the non inductive soloniod has been superceeded with the inductive type. Does this sound correct? I suppose if the older (95-96) PCM didn't look for a signal it wouldn't care if it was there, (as long as it didn't get confused). Interestingly enough, the newer ones are much less expensive. What are your thoughts on this?
Old Feb 13, 2007 | 12:33 PM
puman's Avatar
puman
Reluctantly, (because of long periods on hold), just called the local Ford dealer. Said the numbers have not been superceeded.
woodstockaz
Feb 14, 2017 08:37 PM
bustech81
Apr 8, 2011 12:31 PM
Chris55
Mar 4, 2011 09:04 PM
'83f3fiddy
33
Apr 9, 2010 08:19 AM
FastEddie300
Sep 14, 2004 01:26 PM
