1987 E-350 RV
Old Apr 6, 2010 | 11:52 AM
'83f3fiddy's Avatar
'83f3fiddy
1987 E-350 RV
so im trying to fix my friends RV and they key does NOTHING. its got 2 good battries, and i replaced the little ingition piece on the steering colum with the one from my f-350 (perfect fit) and nothing still. the starter works, the solonoid is new, the fuses are good, the bat. terminals r good, bat wires r good. i cant figure out what is wrong
Old Apr 6, 2010 | 12:09 PM
gearloose1's Avatar
gearloose1
Get a circuit diagram, Volt meter and a test lamp and start checking for power from battery onwards.
Old Apr 6, 2010 | 12:52 PM
'83f3fiddy's Avatar
'83f3fiddy
thats hard haha its got no hood and very little room to get to the motor
Old Apr 6, 2010 | 02:17 PM
Fox Fader's Avatar
Fox Fader
Replace the other ignition switch down on the steering column.
Old Apr 6, 2010 | 03:47 PM
RV_Tech's Avatar
RV_Tech
Do you have power to anything from the chassis battery, gauges, headlights, etc.? Do you have power from the house battery to anything in the coach, overhead lights, 12-volts appliances, etc. ?
Steve
Old Apr 6, 2010 | 04:09 PM
'83f3fiddy's Avatar
'83f3fiddy
everything works except dash guages, and key
Old Apr 6, 2010 | 04:48 PM
RV_Tech's Avatar
RV_Tech
That makes it tougher. I was hoping you would say no power anywhere as I was hoping someone had thrown a disconnect and shut the system down for storage.
Given you have power everywhere else, you know you have a problem with power either to or through the ignition switch, if I am on the right page here. Sounds like this one will involve some lying on your head under the dash. I hate that lay-out!
Good luck,
Steve
Old Apr 6, 2010 | 04:51 PM
'83f3fiddy's Avatar
'83f3fiddy
i replaced the ign thing with 1 from my ford f350 so the switch is good...
Old Apr 6, 2010 | 06:42 PM
Fox Fader's Avatar
Fox Fader
So when you turn the key "on" you get nothing?
Old Apr 6, 2010 | 08:41 PM
'83f3fiddy's Avatar
'83f3fiddy
exactly. i get no power at the key...and i replaced the thing that the key moves with the one from my ford so i know it works. if i jump the starter solonoid the motor will turn over but it gets no fuel or spark at all...even with the key on
Old Apr 6, 2010 | 10:48 PM
Fox Fader's Avatar
Fox Fader
So did you change the key cylinder or the ignition switch on the column below the dash?
Old Apr 6, 2010 | 10:52 PM
'83f3fiddy's Avatar
'83f3fiddy
the ignition thing on the collum, with one that i know works lol
Old Apr 7, 2010 | 07:40 AM
subford's Avatar
subford
Do the headlights come on when you try to turn them on?
If the headlights come on do the parking lights come on also?
Old Apr 7, 2010 | 08:16 AM
Fox Fader's Avatar
Fox Fader
That means the cylinder ignition switch could be bad.
Old Apr 7, 2010 | 09:13 AM
'83f3fiddy's Avatar
'83f3fiddy
where the key goes it still moves the rod thing...and yes, everything works except the motor...but the motor turns over
