My wifes 2002 Screw has developed a click when placing the car in gear. I checked the u-joints and they are tight. Applied grease to the yoke without and change. Is it possible that the rear end needs re-shimmed? This is a 3.73 limited slip rear end.
I always thought a clicking sound from a limited slip rear end was the clutches.
Fluid change needed? Maybe?
Someone with greater knowledge will know more than I.
