desktop dyno'd 545 project cam question
Old Feb 13, 2007 | 04:07 AM
darrin1999's Avatar
darrin1999
i just got a desktop dyno program to run my 545 on, and im thinking maybe i should go more conservative on the cam on it... the powerband is from 2000-5200 rpm- torque is between 550 and 590 all through those numbers but drop sharply outside of that range- and horsepower peak is 550 at 5500 rpm and is very sharp, which it would probably never see without a manual tranny or manual valve body for the c6. what do you all think? think a lower rpm power band would be better for a relatively conservatively driven stroker? or should i just stick with the plan?
Old Feb 13, 2007 | 12:29 PM
airharley's Avatar
airharley
Remember this one fact, HP will not move you. Torque is what moves the truck and HP helps to sustain it. I get strange looks everytime I explain my engine has more TQ then HP. Most of the younger guys always argue it until they are blue in the face. Then when we compare actual performance they still scratch their heads. So I would stick to the actual plan for more TQ.
Old Feb 13, 2007 | 08:56 PM
WILDEBILL308's Avatar
WILDEBILL308
What cam are you using? Have you built it yet?
I am interested as I am building a torque motor and plan on using Lunati #61600 I haven’t gone with a stroker kit yet and I think I think it should get near 525 lb torque at 2000 and about 375 hp at 4500.
Bill
Old Feb 14, 2007 | 12:50 AM
darrin1999's Avatar
darrin1999
the cam is crane cams #359351. its a hydraulic roller retrofit. im debating getting #359341 instead, but i think im going to stick with the bigger one... a little more detonation resistance, and at just shy of 13-1 compression, ill need it, even running propane
i just ran #359331 (the smallest one) and if i could get by without detonation its got pretty much the perfect powerband... 500 ft-lbs at 1000 rpm, peaks at 670 ft-lbs at 2500 rpm and doesnt drop below 500 until 5200 rpm... now thats a powerband oh and its still 550 horse peak- at 5000 rpm
rusty70f100
26
Oct 28, 2006 08:00 AM
RobsRedFord
19
Oct 27, 2004 03:58 PM
BigJake86
Feb 21, 2003 08:12 AM
shazam
15
Feb 16, 2002 09:12 PM
shazam
Jan 30, 2002 07:32 AM
