1978 - 1996 Big Bronco
Quick Question About Fuel Pumps
Old 07-17-2011, 04:27 PM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
The fuel pump on my 93 recently went out, and i'm wondering if there is a particulair brand or model that anyone would reccomend I get or stay away from. I had the unit replaced several years ago when it went out on me out in the middle of nowhere, but I won't know what brand it is until I get it out. A motorcraft one is basically off the table for me since they are at least twice the cost of other respectable (bosh, delphi, etc) brands.
Old 07-17-2011, 05:07 PM
78Explorer's Avatar
78Explorer
78Explorer is offline
I'd like to know that answer too...picking up my Bronco on Tuesday and I suspect a fuel pump issue, as others have suggested it might be. So hopefully someone can relay a good experience with their replacement fuel pump.
Old 07-17-2011, 08:45 PM
deadeyedevon's Avatar
deadeyedevon
deadeyedevon is offline
i know its not what you might want to hear but ive done 4 ford pumps in different vehicles and have all ways stuck with ford parts, i just think fuel pumps suck to do so i pay the extra. i did one in my cousins ranger that wasnt bad but he bought some crappy one from zep boys..a year later we had to do it again,
Old 07-17-2011, 10:42 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
I'll second deadeyedevon's approach to this one. Considering the amount of tedium involved in replacing a fuel pump, there is no reason to skimp on the unit because a lesser brand is more likely to need more frequent replacement.
Old 07-17-2011, 11:17 PM
g_k50's Avatar
g_k50
g_k50 is offline
Quick correct answer, Get your Ford Fuel pump from the Ford Dealer.
Mine lasted 150,000 miles before it acted up, didn't leave me out on the end of the trail either, but it just wouldn't let me race home for the last 70 miles. But I made it home.
And of course Ford re-engineered the fuel pump so I had to solder in the new connectors.
I expect the new pump to last another 20 years and 150,000 miles,
Old 07-18-2011, 04:35 AM
78Explorer's Avatar
78Explorer
Sounds like that's the way I'll go...thanks!
Old 07-18-2011, 09:07 AM
masseysbronco
I hear what everyones saying, but you wouldn't trust one from Bosh or Delphi either? I would never get one manufactured by the auto parts store like duraslast.....I know better than that.
Old 07-18-2011, 09:19 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
I ran a ford pump also last time i had to do a replacement. so to answer you question NO i would not use any other brand.
and are you sure the fuel pump you have is bad?
Old 07-18-2011, 09:46 AM
masseysbronco
Yeah it's the pump. I have a good ground and good power to it. It will work for a short time and then cuts out on you going down the road. It won't work again until it's cooled down overnight. It registers a KOEO code of 542. I tried switching around the relays, hooking ground directly to the pump circuit on the diagnostic connector, etc. It's got some kind of intermittent issue inside the tank. I'll be on the lookout for an obviously broken connection either on top of the tank or inside it, but i'm not going to hold my breath on that one.
Old 07-18-2011, 11:59 AM
masseysbronco
Does the skid plate on the rear-mounted 32 gallon tank actually hold up the tank? The haynes manual suggested that there were still straps behind the skid plate that supported the tank, but now that i'm down to the final two bolts the whole thing seems ready to come out.
Old 07-18-2011, 01:00 PM
drunkdave's Avatar
drunkdave
drunkdave is offline
on my 89 the skid plate is all that holds the tank in.
Old 07-18-2011, 10:26 PM
deadeyedevon
skid plate is all that holds mine up
Old 07-18-2011, 10:52 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
There are two ribs under the skid plate in mine.
mark460
02-13-2015 09:43 PM
ebbnflow
18
04-12-2014 10:00 PM
94_idi_turbo
11-08-2013 09:20 PM
WoomaHodal
06-04-2013 08:57 AM
fish-albuq
13
04-11-2010 11:25 PM
Quick Reply: Quick Question About Fuel Pumps
