Offroad & 4x4
dana70 ?s
Old Feb 12, 2007 | 11:07 PM
captain p4's Avatar
captain p4
dana70 ?s
Where can I get a spool for it? I can't seem to find one.
Also, when looking at the ring and pinions it looks like there is a carrier split like on the d44, right? It looks like the split is at 4.10, but I see some "thick cut" 4.56's.. does that mean they will bolt to the 4.10 and lower numerically carriers?
and how do I tell what ratio is in there now, is it as simple as turning the pinion and seeing how many times around it takes to get one revolution out of a tire?
Old Feb 13, 2007 | 07:48 AM
teds74ford's Avatar
teds74ford
Your best bet for a spool might be a welder.
Yes, thick cut are supposed to bolt to the numerically smaller carrier.
The easiest way to verify ratios is to count the teeth on each gear (R&P) and divide. Is the cover off?
Old Feb 13, 2007 | 10:25 AM
captain p4's Avatar
captain p4
Nope, its still sitting under the parts truck. Haven't had time to mess with it yet.
Old Feb 13, 2007 | 11:23 AM
blucollar4xford's Avatar
blucollar4xford
you can get a rough estimate by marking the pinion and the tire and counting the revs the pinion makes vs on rev of a tire. like i said, its a rough guess, but there arent many ratios that are really that close to screw it up.
Old Feb 13, 2007 | 01:25 PM
captain p4's Avatar
captain p4
Well, I'm just trying to figure out which side of the carrier split I'm on. I already have 4.56's for the front sitting in a box waiting to go in. Once I get it under there and set up how I like I can start piecing together the 8lug conversion for the d44.
Old Feb 13, 2007 | 06:48 PM
captain p4's Avatar
captain p4
what weight gear oil should I run in the d70?
Old Feb 15, 2007 | 08:13 PM
captain p4's Avatar
captain p4
So, we looked at it tonight and we think it's a limited-slip. What a find!
-Dubzilla, posting for p4
Old Feb 15, 2007 | 10:53 PM
captain p4's Avatar
captain p4
Ok, I have a couple more questions for you guys. I feel like such a asking these questions, but I've never worked with this stuff before and I don't know where else to find out.
1) brake lines - they just unscrew from the drum on the donor and then the lines on the bronco will screw right into the d70 drums?
2) emergency brake cable - I can't figure out how to get this thing out of the drum.
3)nevermind-figured this one out with my haynes manual.
4) diff vent - I'm assuming its just a hose barb holding that thing on there, but i didn't want to start yanking on it without being sure.
5) diff fluid - what level should it be at? all the way up to the fill plug?
and as dubz said, it is apparently a limited slip, which I guess is better than being open.. i wasn't planning on spending the 400 or so on a locker anyway. we also found out that it is a 3.50ish ratio which matches the stock bronco gears so I don't have to regear right away...even though I probably will.
Old Feb 16, 2007 | 11:17 AM
mark a.'s Avatar
mark a.
If it's around 3.50 it's a 3.54. Last time I checked those 4.56 thick Dana 70 gears were a lot of $.
Old Feb 16, 2007 | 11:41 AM
captain p4's Avatar
captain p4
Yeah.. they are. are 70u and 70 ring and pinion gears the same? I can't find any that say 70u.
Old Feb 16, 2007 | 04:33 PM
mark a.'s Avatar
mark a.
As long as they are both Ford rears.
joe_13894
Feb 1, 2012 09:58 AM
TenHoles
Jan 24, 2012 06:39 AM
Thunderjet4x4
Oct 2, 2008 12:37 AM
roofmower
Jul 18, 2006 07:17 PM
Destroyer
Sep 26, 2004 09:13 PM
