1978 - 1996 Big Bronco
transmission
Old Nov 21, 2002 | 01:40 PM
aj5601's Avatar
aj5601
transmission
ok, my c6 is acting funny now!!! it shifts really smooth and doesn't slip. but my problem is going from park into a drive gear. it doesn't want to get into gear. it has plenty of fluid and all. even going from R to D it takes its sweet time. anything i can do, or do i need a rebuild?
Old Nov 21, 2002 | 02:36 PM
fcarruth's Avatar
fcarruth
transmission
I don't know anything about anything other than my AOD but that is what mine started to do before I ended up rebuilding it. Like I said, get some others advice here and don't count on what an AOD only guy thinks.
Old Nov 21, 2002 | 06:02 PM
mweeps's Avatar
mweeps
transmission
Is it just the linkage? What do you mean by takes it sweet time to go from Park to Drive? Once you move the shifter it takes a second before it actually shifts into drive? how many miles on it all my C6 trannys have shifted flawlessly even after 100K miles.
Old Nov 21, 2002 | 10:43 PM
Ford_Six's Avatar
Ford_Six
transmission
It probably has a sticking accumulator. Does it shift hard when you floor it? If not, it probably needs to be gone through.
Jared
Old Nov 22, 2002 | 07:53 AM
aj5601's Avatar
aj5601
transmission
when i say it takes its sweet time, i mean when it is cold it takes like 5 min...no joke. i have to put it in drive and sit there till it decides to go into drive. when it is warm, it is more like 5-10sec. i know it takes a lil time to change gears and all but my old c6 i have behind a 460 never acted like this. that tranny as soon as it hit the D it was in drive without hesitation. the tranny has about 150,000 i think.
Old Nov 22, 2002 | 09:00 AM
jimandmandy's Avatar
jimandmandy
Post transmission
It's just plain worn out. That is how most Ford automatics die, they get real slow to engage when cold. 150K is a good lifespan for an automatic. A C-6 with no major broken parts should be cheap to rebuild. The newer E4OD is a nightmare by comparison.
Jim
Old Nov 22, 2002 | 10:34 AM
fcarruth's Avatar
fcarruth
transmission
As a last case ditch effort, I think that I would try to drain about 2 quarts and then add back 2 quarts of Lucas Transmission Fluid. It has great sticking grabbing abilities and is a great product. I have read of a few last efforts that this resolved problems.
Definitely can't make it any worse huh ?
Like Jared said, check your accumulator first though.
Old Nov 22, 2002 | 12:01 PM
RonBo's Avatar
RonBo
transmission
SeaBassHWD
Aug 9, 2019 06:00 AM
Logan Anderson
Jan 29, 2017 08:06 PM
Jacob Lowell
Nov 30, 2016 08:10 PM
Mikes150
2009 - 2014 F150
Sep 29, 2015 12:37 PM
drpconstruction
Dec 17, 2005 07:19 AM
