Removing emissions stuff, 300 I6?
Secondly, with this stuff removed, will the damper door in the snorkel on the breather continue to operate? There are two hoses going to the bi-metal valve. One comes from the carb to the bi-metal valve in the top of the breather. Another comes from the bi-metal valve to the vacuum motor that controls the damper. I left these intact (or would I be better off to disconnect this stuff as well)?
Not sure, but it does seem to have lot more power with this stuff disconnected. As a side note, the EGR valve is nearly new. If anyone needs it and has a EGR block-off plate, I would be willing to swap.
Thanks in advance!
i pulled all the eq on mine, and since my vacuum lines were all rotted through, i left it that was for 10,000 miles. i'm replacing a few when i finish the rebuild... maybe.... (mechanical choke, mechanical secondaries, and looking at mech advance DUI distributor) i didn't have any real problems, aside from mileage suffering from the lack of vacuum advance
thanks,
If you cant find em' grind em'
Last edited by mountaintruck1; May 29, 2019 at 04:56 PM. Reason: needed to add more details
thanks,
You probably have a feedback carb like me. You either need to restore the vac lines per the diagram next to the radiator or do a dura spark conversation to eliminate the computer control. That is what I have gathered so far. I do not have an air pump and the tube to my cats are disconnected. I have restored everything else by finding g NOS parts and buying new silicone vac lines.
You'll probably have a tough time passing emissions without doing some work to that system. The issue you're going to run into is that the carburetor was computer controlled, as was the timing. Without the proper sensors in place, computer is going to make the carburetor run rich (a safety "LIMP" mode) and prevent the distributor from advancing the timing.
Since you eventually plan on going with a 4bbl carb and the EFI manifolds (which I have passed emissions with easily), I'd at least look into getting a proper ignition to match your setup, since the TFI will not work with either. Either a DuraSpark II or something aftermarket that works off of a vacuum advance. This will help a lot with getting the system to run properly.
Then, from what I've heard, you can remove the solenoids on the feedback carb and use pliers to grab and adjust the idle mixture.
That should get you close.
Thanks!
I did do some more reading and what you say confirmes this. I just have to get a tractor first in order to remove my head from rear end to get it done right. I wasn't excited to "downgrade" per se to an older setup just because i didnt want to mess with emissions stuff. I was also just concerned whether its more fuel efficient than "functioning" stock setup with emissions. Some users say yes the stock is engineered for it best mpg and others say no that its restricting the system and numbers seem to back it up, But that answer is maybe on another thread, probably. Im glad you pass emissions with your setup. That makes me more confident in my own conversion /removing emissions stuff.
Anyway, have been looking into vacuum dizzy and its like $50. Slap it in there, time it, then bolt manifolds on there and adjust the carb. Just saw your post on a DSII conversion thread BTW (lol) I will see how that works until i can kick out the pile for a new intake/ carb. Your system is pretty close to what im aiming for. Sidetrack: What site did you get your offy?
Thanks!
If you can't find em' grind em'
I definitely wouldn't consider swapping out your ignition for the DuraSpark II a "downgrade". It's considered one of the more efficient and reliable setups you can get. The TFI and feedback carb setup was more of "bandaid" before they could make the switch to fuel injection. It was only used for 3 years.
On your '85, the Duraspark II setup will be plug and play. You'll at minimum need the distributor and ignition module. You'll also need a wiring harness and can either find it in the junk yard, buy it new, or just wire it up yourself if you're okay with that. I made a wiring harness for my setup pretty easily as there's plenty of schematics around. If you get a stock wiring harness, you'll either need to get the correct year coil, or rework the wires to match yours. Not too hard.
I got my Offy DP intake used off of eBay years ago, and then traded it for the Offy C with another member here on the forums. So, I never bought one new. They seem to be jumping up in price about $25 - $50 every six months to a year now, so I'd keep an eye out on eBay, or buy a new one sooner than later, so the price doesn't go up again.
If you use a different aftermarket coil (most of them come with screw/nut posts), then you'll need to just cut off the coil "horseshoe" clip, and wire on some connectors. No big deal.
