6.9 diesel to a 460
Old Feb 12, 2007 | 05:36 PM
jsarver11's Avatar
jsarver11
Question 6.9 diesel to a 460
hi fellas i have a 1984 f-250 with the 6.9 diesel in it and it is right now under complete restoration. i am having trouble deciding what to do about the motor and have recently been flirting with the idea of dropping in a 460. does anyone know where i could find more info about doing this or better yet has anyone done it? i found a place that sells the motor mounts to do the conversion but i still have many questions like will the 4 speed manual still bolt up? what kind of wiring dilemmas am i getting into? will the rest of the drive train work out like the transfer case, drive shaft length, and do i need new rear gears? any help would be greatyl appriciated.
thanks guys,
Jsarver11
Old Feb 12, 2007 | 10:02 PM
77SilverStreak's Avatar
77SilverStreak
Our buddy did the opposite swap on his 83 F250 4x4. He went from the 460 to the 6.9. I can tell you that the bellhousing is the same as the 460, just the 6.9 has an adapter plate that is bolted to the block to make it fit to the 460 bell housing. You will need different motor mounts as well. What our friend did was buy a donor truck with the 6.9 in, and used the wiring harness, dash, fuel tanks, etc. to get it in. For gears it depends what you have, but that can cost alot to change since gears aren't cheap. The rest of the powertrain will work no prob. Just the wiring is the worst, but I suggest finding a donor truck, lots in the junkyards!
greythorn3
27
Feb 8, 2008 08:00 PM
jsarver11
13
Oct 2, 2007 07:23 AM
jsarver11
Jul 17, 2007 09:05 PM
jsarver11
Nov 11, 2006 11:34 AM
10 Mistakes Secretly RUINING Your Truck's Fuel Economy
Slideshow: 10 Mistakes that are ruining your truck's fuel economy.
By Joe Kucinski | 2026-04-14 11:18:36
Someone Built This Insane 6-Door Ford F-450 Dually
Slideshow: Built by Stretch My Truck, the extended heavy-duty pickup adds a third axle, twin-turbo diesel power, and a supercar-territory price tag.
By Verdad Gallardo | 2026-04-06 20:04:27
10 Things Most Likely to Break on a Ford F-Series (& How to Fix)
Slideshow: 10 things most likely to break on a Ford F-Series and how to fix it.
By Joe Kucinski | 2026-04-06 11:28:20
7 Classic Ford Trucks You Can Drive for 'FREE'!
Based on their soaring values, these Ford trucks haven't lost any of their value - and some have even become profitable compared to MSRP.
By Brett Foote | 2026-04-06 10:53:38
1976 Ford F-250 Project: More Rock Crawler Than Garage Queen
This is one classic Ford truck that isn't living the pampered life.
By Brett Foote | 2026-04-06 10:42:34
The 5 Best (and 5 Worst) Ford Truck Collaborations!
Slideshow: The 5 best and 5 worst Ford truck collaborations.
By Joe Kucinski | 2026-04-01 13:52:52
