6.9 rebuild
Old Nov 7, 2006 | 02:26 PM
jsarver11's Avatar
jsarver11
6.9 rebuild
i have an 84 f250 with the 6.9 and was wondering if anyone had ever attempted to rebuild the motor? any suggestions or books to look at? what about rebuild kits? does anyone offer them?
thanks,
Jamie
Old Nov 7, 2006 | 09:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I never attempted to rebuild it, I did rebuild it.
Old Nov 9, 2006 | 12:15 PM
jsarver11's Avatar
jsarver11
where did you get your parts from? did you use any kind of books as a guide? is it easier than rebuilding a gas motor?
thanks,
Jsarver11
Old Nov 9, 2006 | 09:17 PM
Dave Sponaugle
I found a good machine shop and ordered most of the parts through them, they had very good prices.
Most of the engine parts are Sealed Power.
The only thing that I used as a guide was the torque specs just to make sure I did not get them in the wrong place.
Same basic principal as a gas motor, tolerances are closer, everything weighs more and parts are more expensive though.
Where do you live?
Do you use a block heater?
How many miles on the engine you have now?
What is your intended use after the rebuild?
Are you trying to get more power or thinking about adding a turbo?
I did a lot of stuff not in the books on that engine.
Old Nov 9, 2006 | 10:24 PM
jsarver11's Avatar
jsarver11
i live in pa and i do use a block heater it gets pretty cold here in the winter. the motor has about 150000 miles on it but it uses a lot of oil and blows white smoke when it idels. i would like to just build it so i know everything is strong and sealed and so one day when i add a turbo it will be able to handle it
Old Nov 11, 2006 | 01:11 AM
lowboy250's Avatar
lowboy250
How much money did you have into your 6.9 by the time that you were done?
Old Nov 11, 2006 | 11:34 AM
Dave Sponaugle
About 4000 dollars for parts and machine work.
I had a few extras at the machine shop so I could run high boost like the piston tops milled down to lower compression a bit.
I also had it bored to 30 over.
I am running 7.3 rockers.
IP and injectors are from a 94 7.3 turbo motor.
Aftermarket ATS turbo with a 3" outlet and exhaust.
ARP headstuds keep the heads in place.
Hypereutectic pistons whick are stock have better heat resistance so that is the way I went.
150,000 miles is not much, is your CDR working correctly?
Mine had 300,000 on it when I changed the engine.
jamie7375
Jan 14, 2010 11:48 PM
jamie7375
Dec 22, 2008 04:50 AM
jamies460
Jul 28, 2007 06:41 AM
jamies460
May 5, 2007 03:51 AM
jamies460
Jan 16, 2007 07:59 PM
