Granny gear
Old Feb 12, 2007 | 03:50 PM
79oneton's Avatar
79oneton
Granny gear
Will a 1979 F-150 4X4 5 spd mannual transmission(low 1st gear) be a dirrect swap to a 1996 F-150 4X4 5 spd mannual(high 1st gear)? 5th gear in each is considered overdrive. What are the part #'s for each tranny? What about the transfer case? The 79 is a 300 6 cyl. and the 96 is a 302 v-8. I gotta believe the 79 tranny is superior to the 96 tranny. Thanks
Old Feb 12, 2007 | 03:59 PM
andym's Avatar
andym
The bellhousings are compatible, so they will bolt up. The transfer case should also bolt up, but you will have to shorten/lengthen the linkage to get it to fit right.
However, no '79 F-150 came with a 5 speed, so I have no idea what tranny that would be - maybe someone swapped in a ZF?
Big John Hance
Oct 5, 2022 09:40 AM
gaffmedic
Apr 5, 2017 02:15 PM
caribcanuk
Nov 6, 2016 11:10 PM
HondaRider137
Feb 12, 2016 09:44 AM
Trapperpete52
Jan 20, 2016 09:58 AM
