Banjo bolt
Old Feb 12, 2007 | 10:42 AM
Martin Broll's Avatar
Martin Broll
Banjo bolt
Now that I have a brake pedal again, I can move to the next problem...
I have the same leak that I read about in previous post,the banjo bolt
Does any-one know what size it is ? Standard or Metric? I had a 32mm socket on it this morning but it felt a little sloppy!!! I will borrow a wrench tonite at work, I think the box end backwards may be enough to tighten to see if the leak stops before replacing any-thing!!! Sunday I tightened all clamps in that area!
Marty
Old Feb 12, 2007 | 01:21 PM
tjbeggs's Avatar
tjbeggs
I think it 1 1/4 but don't quote me on that. hopefully somebody who has a better memory than me will confirm or flame me!
Old Feb 12, 2007 | 01:55 PM
JMorton's Avatar
JMorton
I was thinking 1 1/8 but I may be wrong.
Old Feb 12, 2007 | 02:59 PM
Freakazoid!'s Avatar
Freakazoid!
I am also pretty sure it is 1 1/4". Don't forget to replace the gaskets on either side of the hard line - I had to get them from the dealer, which took two days to arrive, so give yourself some leadtime.
