DIY-injectors Article
Old Feb 12, 2007 | 01:54 PM
JMorton's Avatar
JMorton
I've seen a lot of questions about these so I thought I'd post this up. Hope the mods don't delete it, it's a good article.
http://mrtruck.net/injectors.htm
Old Feb 12, 2007 | 03:02 PM
big inch's Avatar
big inch
Could you tell a noticeable difference when you did your injectors?
Old Feb 12, 2007 | 03:14 PM
JMorton's Avatar
JMorton
Seat of the pants difference wasn't what I had expected, but then again it is a 7300 lb truck. The difference I really noticed was the change in acceleration. On my first run, the area where I finally looked at the speedo, I would usually be around 80-85 mph with the stockers. With these I had the speedo pegged at the same spot. It accelerates FAST now! Can't wait to gt the camper out and tow with them and see what it does.
Old Feb 12, 2007 | 04:49 PM
Power Strokeme's Avatar
Power Strokeme
I wonder if you didn't see the gains you expected because you didn't get a chip. In the article he already had a chip calibrated for the injectors B-4 he started.(at least thats the way I read it) OOPs, I see you have a chip (not one I'm familiar with) do you need to have it recalibrated maybe?
Old Feb 12, 2007 | 05:09 PM
JMorton's Avatar
JMorton
No, I installed the Wildman (Tony Wildman)chip, calibrated for 160 cc injectors before I rebuilt the injectors. I was thinking it would feel more like a car with nitrous, like it wouldthrow me back in the seat really hard. I think since the truck is so heavy, I don' feel that as much as I would say in a 3000 lb car. You read the article correctly, that's how I intended it to read.
