Turbo Oil
Old Feb 11, 2007 | 08:59 PM
dvfd12's Avatar
dvfd12
Turbo Oil
Is the oil for the turbo supplied by the HPOP? I ask because the parts guy at the dealership told me that having a chip or programer is what causes the EBPV to leak because of higher oil pressure.
I was just wondering if this could be true or just a line of BS.
Old Feb 11, 2007 | 09:03 PM
Fire Rooster's Avatar
Fire Rooster
He is full of BS. The turbo is fed by oil from the low pressure system.
Old Feb 11, 2007 | 09:06 PM
dvfd12's Avatar
dvfd12
That is what I thought, but I wasn't sure.
Old Feb 11, 2007 | 09:13 PM
tjbeggs's Avatar
tjbeggs
ya watch it next he will tell you it leaking cause your bypass filter is removing all the sealers added to the oil!
Old Feb 11, 2007 | 10:16 PM
redstroker1's Avatar
redstroker1
Hey guys, I was taking things apart trying to get to my valve covers to replace glow plugs and noticed that there was oil all in my turbo pipes and it is leaking out somewhere on top of motor. Looks like it is leaking from the orange rubber boot that goes from bottom of turbo to top of motor. Any suggestions would be highly appreciated!
Old Feb 11, 2007 | 10:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
On the driver's side Valve cover there is a box, with a 90* elbow going upwards into the intake tube. Replace the plastic connector with a piece of 4" scrap exhaust pipe from a big-rig shop, and then attach a hose to this 90* elbow, and then route it away from the engine, under the truck somewhere. This is known as the CCV mod, it directs CrankCase Vent oil out of the intake, it's only there for emissions reasons, and that is the oil you see.
Old Feb 11, 2007 | 10:38 PM
BobbyDiesel71's Avatar
BobbyDiesel71
what dealership told you that?
Old Feb 11, 2007 | 11:18 PM
redstroker1
Hey Kris, so that explains the oil all over top of the motor and also the oil inside the turbo pipes? Also, I got the glow plugs out and hooked them to a battery and two of them were bad and the other 6 lit up. Is 2 bad ones enough to cause all this cold morning no start stuff?
Old Feb 12, 2007 | 01:35 AM
aklim's Avatar
aklim
I thought that oil pressure is less than 60psi while HPOP pressure is in the thousands of psi?
That parts guy is on crack.
Old Feb 12, 2007 | 01:37 AM
aklim's Avatar
aklim
If the air is cold and the plugs are not all glowing, it could make things harder to start.
Old Feb 12, 2007 | 06:37 AM
dvfd12's Avatar
dvfd12
The dealership in Carrolton IL. He was the only one in the state with the parts. The guy also charged me $50 more than the local guys would have if they had had the parts. Oh well, I had to have it going for this week.
