350 4x4 front suspension issues.
Old Feb 10, 2007 | 10:18 PM
motoman's Avatar
motoman
Im in the process of weeding out a loose front end, ball joints are good, I know the tie rods are pretty bad as well as the box is loose.It turns right fine but fast left handers seems to have terrible understeer. Im at odds with the trac rod and why on a leaf sprung front end. I replaced the front shackles as the bushings were shot and their narrowness is perhaps the reason for a trac rod. It seems abnormal that from the factory it runs at such an angle. compressing the front springs will push the diff to the left pretty substancially. If it was level it would eliminate the problem.Very similar to a coil sprung jeep TJ or XJ. Anyone try removing the rod and see how it worked?
Old Feb 11, 2007 | 06:26 AM
bluefishgary's Avatar
bluefishgary
I have removed my track bar in 95 on my F-350 4X4 it's a 1994 60,000 miles later no problems. Now at the same time I removed the small front shackles
and put in a kit witch had much larger ones, had to drill the frame and weld
in new tube for bushing easy kit to do . I use the truck to hall a very large slide in camper and it's ben fine. I would not remove with out replaceing the front shackles as the stock look weak to me.
Old Feb 11, 2007 | 09:51 AM
motoman's Avatar
motoman
Where did you get the kit? or what did you use for wider shackles? I replaced mine with new factory ones but as you mention the top is only about 1.5" wide and would provide 0 lateral stability in turns etc. I also am setting mine up to haul a slide in camper.
Thank you.
Old Feb 11, 2007 | 10:24 AM
bluefishgary
Try Off Road Unlimited they do not show it on web site but they do show the
shackles reversial kit.
Old Feb 11, 2007 | 02:53 PM
Tdvjensen's Avatar
Tdvjensen
have you tried replacing the bushings in the track bar? The older style broncos have a similar track bar and i replace the bushings in it almost anaully. The mounts on the frames of the these trucks also come loose and it is hard to tell. Have some one quickly wiggle the steering wheel about 1/8th of a turn while you look under the front of the truck, with the wheels one the ground. If something is loose, it will show that way.
Old Feb 11, 2007 | 03:24 PM
motoman's Avatar
motoman
I`ll do that. I still get some clunking on bumps and after the shackle install/u bolt retorque and setting the tires to 40PSI Im getting mild death wobble after hitting a bump. Damn Dodge POS I finally called it quits on is gonna haunt me till the day I die. D/W deluxe in that thing, almost as bad as my jeep TJ. Ive bever had a straight axle leaf sprung truck do this, Kinda weird. I should probably install and steering stabilizer as well, probably wouldent hurt.
Old Feb 11, 2007 | 03:29 PM
Tdvjensen's Avatar
Tdvjensen
I wouldnt reccomend the steering stabilizer since they mask real problems such as yours. Its more like a bandaid fix. I would check it out and see like i mentioned. Death wobble is a classic symptom of the track bar bushings and mounts. Get some nice aftermarket poly bushings for it, cause when i did the ones in my bronco the first time, the napa replacements were no better than my worn out ones.
Old Feb 11, 2007 | 04:52 PM
motoman's Avatar
motoman
Thank You for the info, Id imagine energy suspension sells poly bushings. Its goin in tuesday for tie rods and alignment. i have a leak in the PS system also thats minute but messy, looks like the pump shaft seal but not sure. Ive considered replaacing the box and pump, their fairly cheap considering. I feel like a kid in a toy store regarding repairs on this truck after the Diesel dodge got rid of. I had 8K in repairs in 3 years and still needed another 2k fix again for the second time in 30K. man I had bad luck with them things.
Old Feb 11, 2007 | 07:52 PM
Tdvjensen's Avatar
Tdvjensen
I know what you mean. I went nuts on my 92 after I bent up the front suspension and the motor blew up. The only thing stock is the body and the frame. I did it all myself aswell so I saved a bit by not taking it to a mechanic for it. The number of hours I have on it, I cant even imagine what the price tag would have been for it to be on the clock. Good luck.
pin8246
Sep 7, 2012 07:55 PM
JaysRanger
Apr 18, 2010 01:36 PM
Skip1970
Mar 2, 2010 02:57 PM
gcfisher75
Feb 4, 2007 12:28 AM
