carb size?
Old Feb 18, 2007 | 05:57 PM
  #31
bbf150's Avatar
bbf150
yeah i'm leaning toward a 750dp-just better tuning capabilities,my buddy had a 700dp-seemed good down low but it just flatened out up top-he ran a 750vac and it just wasn't there like the mech carb-then he went to a 750dp-now he's happy,his motor was a little more mild than mine too
Old Feb 18, 2007 | 08:45 PM
  #32
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
I would go with a vac secondary over a mechanical. You can easily adjust the tip in on the secondaries with a vac sec carb by just changing springs. A spring kit is a few bucks. There is also a quick change spring cover available.
Old Feb 18, 2007 | 09:03 PM
  #33
bbf150's Avatar
bbf150
i've run the lighter springs and you can make them run better but then it knocks mileage-my 600 went from 10 to 7mpg going to the lighter spring-my #4776 600dp runs circles around my old #1405 600 edelbrock and #1850 holley 600 vac-and i'm getting 12mpg
Old Feb 18, 2007 | 10:37 PM
  #34
bronco521's Avatar
bronco521
dp just need two 3/8 wrenches for all the tunability on the pump circuit you could need.
jrockdiddy
Jan 10, 2013 06:25 PM
GillisB93
Nov 22, 2012 06:30 PM
Kirbys73F100
Jul 16, 2010 09:25 AM
mattyzx3
Sep 8, 2007 12:38 AM
Wakeboarder141
Apr 2, 2007 10:12 PM
