Sponsored by: Auxito
Cold Start Problems
Old Feb 9, 2007 | 04:40 PM
BLackFenton's Avatar
BLackFenton
Cold Start Problems
My Truck will not start up right away if the engine[4.6L V8] is too cold or hasnt been driven like over a good amount of time if i throw it in Nuetral give a little gas @ 1500 RPM for a good minute itll run Otherwise it will Stall after its taken out of Park / Neutral .......PLZ help if any knowledge is known
Old Feb 9, 2007 | 07:48 PM
torkum's Avatar
torkum
Do you have a CEL or any pending codes? If no codes found, it sounds like a IAC problem.
Old Feb 10, 2007 | 07:19 PM
BLackFenton
what does all that mean
Old Feb 10, 2007 | 07:30 PM
LxMan1's Avatar
LxMan1
CEL = Check Engine Light.
IAC = Idle Air Control valve. Usually the culprit with idle problems.
Old Jun 4, 2007 | 11:57 AM
BLackFenton
How do chekc/Fix the IAC prob
Old Jun 5, 2007 | 03:57 PM
KingRanchMan02's Avatar
KingRanchMan02
Some have had success with removing it, then cleaning it with some carbureator/throttle body cleaner. Others don't have the paitence for that and just replace the IAC with a new one. Good luck!
Old Jun 6, 2007 | 01:24 PM
BLackFenton
thanx this has been an annoying prob ever since i install my new air intake ..ima get right on this thanks again
Old Jun 6, 2007 | 02:23 PM
Help_Me!'s Avatar
Help_Me!
Does anyone know where the IAC is on the K&N cold-air intakes for a 2001 Ford F150 4.6L? I've got a similar problem. The truck hesitates to start sometimes. It will start a bit, then seem like it's going to stall, and then rev up again and run OK.
Old Jun 6, 2007 | 03:35 PM
KingRanchMan02
The IAC is not located on the intake air duct. It is mounted directly to the throttle body. Good luck!
Old Jun 7, 2007 | 12:23 PM
Help_Me!'s Avatar
Help_Me!
Gratzi! I'll check it out. It seems like one thing after another with this truck, and for some reason, I still love the thing.
Old Jun 8, 2007 | 10:28 PM
BLackFenton
whut is it on the throttle body ......same feelings if its not one thing its another yet i still wanna keep it
Old Jun 11, 2007 | 10:52 AM
KingRanchMan02
The IAC (Idle Air Control) valve is attached to the throttle body. The throttle body is the butterfly valve that you open and close with the throttle cable when you push on the gas pedal. Good luck!
Old Jun 13, 2007 | 02:22 PM
BLackFenton
I meant where is it on the throttle body lol ...but doesnt matter gettin a complete Rebuild done soon THANKS ALOT THO!
Old Jun 13, 2007 | 03:50 PM
KingRanchMan02
If I am not mistaken, it is on the back of the throttle body on the right side.
Ericasands
Apr 2, 2014 06:38 PM
Nice Work Truck
Connecticut Chapter
226
Mar 31, 2014 06:43 PM
97_Stroke
15
Mar 5, 2013 08:15 PM
brcwelding
Feb 6, 2012 09:16 PM
afastone
Feb 15, 2007 06:54 PM
