cold starts
Old Mar 2, 2013 | 09:57 PM
97_Stroke's Avatar
97_Stroke
cold starts
Update on the tribute truck it starts but only on cool or cold days. Any ideas on the cause?
Old Mar 2, 2013 | 10:01 PM
ReBilld's Avatar
ReBilld
Oil level or condition would be all I could think of.
Old Mar 2, 2013 | 11:54 PM
97_Stroke's Avatar
97_Stroke
Oil was changed out when we replaced the high pressure pump
Old Mar 3, 2013 | 12:06 AM
ReBilld's Avatar
ReBilld
Did you replace the IPR, or put new o-rings on the old one?
Old Mar 3, 2013 | 12:10 AM
97_Stroke's Avatar
97_Stroke
IPR I'm thinking, is that the part on the top of the motor that is like a sensor looking at the motor it would be in the top right
Old Mar 3, 2013 | 12:14 AM
ReBilld's Avatar
ReBilld
The IPR is a solenoid valve that screws in to the back of the HPOP. It's got a tin nut that holds the solenoid on the stem, and it takes a 1 1/8" wrench or deep well socket to take the valve out of the HPOP.
Old Mar 3, 2013 | 12:16 AM
97_Stroke's Avatar
97_Stroke
Not sure, looking at some images of the ipr and I looks like the part that screws into the top of the motor if that's it then yes it was
Old Mar 3, 2013 | 12:17 AM
ReBilld's Avatar
ReBilld
Looks like this.....
Old Mar 3, 2013 | 12:19 AM
97_Stroke's Avatar
97_Stroke
Yes that's the one
Old Mar 3, 2013 | 12:21 AM
ReBilld's Avatar
ReBilld
Did you put a new one in the new HPOP? Here's a pic showing it's location.
Old Mar 3, 2013 | 12:27 AM
97_Stroke's Avatar
97_Stroke
Good question I'll get with my mechanic and see I can see the part where its located and that one was not replaced that I know of
Old Mar 3, 2013 | 12:29 AM
97_Stroke's Avatar
97_Stroke
I replaced something that looks like that but don't think that was it. Thank you
Old Mar 3, 2013 | 12:32 AM
ReBilld's Avatar
ReBilld
Hope that helped.
Old Mar 3, 2013 | 12:33 AM
97_Stroke's Avatar
97_Stroke
I believe what I replaced was the ipc
Old Mar 3, 2013 | 12:38 AM
ReBilld's Avatar
ReBilld
Usually not starting after it's hot is low injection control pressure. If you changed the HPOP and the old IPR was put back in, the o-rings may have gotten damaged or something. Just a guess though.
