Power brake install options (hydroboost)
Old Feb 9, 2007 | 01:24 PM
Purely Ford's Avatar
Purely Ford
What are my options to switch an F100 to power brakes? I heard about a hydroboost system that is found on the Astro Van that may work because of clearance issues. I really don't have any knowledge on what to do for this switch.
I do have a power brake booster which will barely clear the tall aluminum valve covers I am using on a 428 FE. It does look just like correct one used on trucks like mine with a stock 360 FE with original valve covers. Those valve covers are shaped in such a way that the booster has plenty of clearance.
Basically, I just need to know what is the best/easiest way to convert to power brakes. I may have asked about this years ago, but then maybe someone has discovered a new way to convert this since then.
Old Feb 9, 2007 | 03:04 PM
Mil1ion's Avatar
Mil1ion
The 9 1/4" dual-diaphram booster from a F350 allows enough room for the tall valve covers.
There is a couple of hydroboost threads in this forum.
Old Feb 9, 2007 | 07:58 PM
Dave Severson's Avatar
Dave Severson
There are also some aftermarket 8" dual diaphram units available, they work great!!!! I've used them on a few cars and really like them....
Old Feb 10, 2007 | 12:33 AM
Purely Ford
Would I be able to get these from a local parts store, or have to order through FTE?
Old Feb 10, 2007 | 01:35 AM
Mil1ion's Avatar
Mil1ion
You can find all the info you need here.
http://www.precisionrebuilders.com/p...ogPHB-0398.pdf
scott79
16
May 18, 2015 04:28 PM
okie72
Feb 15, 2014 09:35 PM
BlueOvalRage
Jun 1, 2010 02:24 PM
rc1099
Sep 3, 2009 12:11 AM
broncman
Feb 7, 2006 12:23 AM
