Offroad & 4x4
Reverse 203/205 Doubler
Old Feb 9, 2007 | 02:18 AM
drunknmudder77's Avatar
drunknmudder77
I had the idea the other day at work to take a 203/205 doubler set up & turn around the 203 to make an overdrive. The only real problem I see is if the 203 could handle the power going backwards. The adapters shouldnt be a problem at all since you can get just about anything to bolt up to anything nowadays.
The funny thing is I was only trying to figure out how much lift to do to fit 46s & not be to tall, then got to messing around with axles & gears (2.5 tons w/ 46s = 3000 rpms @ 60 mph).
James
Old Feb 9, 2007 | 10:42 AM
fishmanndotcom's Avatar
fishmanndotcom
why are you tryin to reinvent the wheel? you arent adding overdrive, you are still effectively reducing gears. also you'd spend a lot of money towards getting this adapter made since i have never heard anyone doing this. yhes i am sure someone has somewhere, but why get the expensive custom adapter made when you can buy the 203/205 adapter that has been proven and is only gettin cheaper ?!?!?
-cutts-
Old Feb 9, 2007 | 12:37 PM
chrono4's Avatar
chrono4
who want to go 60 with 46's?
Old Feb 9, 2007 | 01:21 PM
75F350's Avatar
75F350
I can appreciate the concept, but I have to question the practicallity of trying to "overdrive" a big ol truck. If this thing was going to do some major cruising at super highway speeds, and you were looking to get better gas mileage, I might be able to understand, but, you mentioned 46" rubber, and "rockies" that have a 6.72:1 gear ratio. I really don't see this thing buzzing down the freeway with the cruise control on at 70 to 75 mph.
My chart shows 2886 rpm at highway speed with that gear ratio, this seems pretty ideal to me.
Pipelinewelder20
15
Oct 2, 2014 03:56 PM
TheTowingCowboy
Jan 15, 2012 09:51 PM
79Ford4x4
Offroad & 4x4
53
Jun 30, 2010 08:32 PM
highboy 74
Offroad & 4x4
Sep 7, 2005 12:12 AM
thesprocket26
Mar 10, 2005 02:03 AM
