Transmission mount nut size
Old Feb 8, 2007 | 05:35 PM
88F-150pimp's Avatar
88F-150pimp
Ok, when I unbolted the crossmember to transmission mount nuts (oil pan gasket change), I snapped one of the studs, so I had to buy a new transmission mount. Well, as one of the nuts is welded to the stud, I have to go get a new one. The ford dealer has none and cannot order any, but the parts guy said it was a 7/16" corse thread nut. I thought that was weird, because I had to use an 18mm socket to get it off. But then again, a 3/4" thread is too big, and I thought maybe the factory nuts had standard threads, but a metric width (you never know). I got a 7/16" corse thread nut, which is too small, go figure. Does anyone know the actual size of the studs on the transmission mount before I go off to the hardware store again for a nut? Is this seriously like the only place on a 1988 truck where they use metric fastners? Oh Ford...
Old Feb 8, 2007 | 05:46 PM
gustang818's Avatar
gustang818
If you still have the old mount or the broken stud take it with you to the hardware. While I don't remember what size they were, I had to get some last fall and they were metric. Generally engine fasteners are SAE and body/chassis are metric.
Old Feb 8, 2007 | 06:24 PM
fordfaninIL.'s Avatar
fordfaninIL.
I would say that it is an m12x1.5.
ak-angler
Modular V10 (6.8l)
302
Nov 25, 2023 02:39 AM
cberr
1997 - 2003 F150
22
Jan 27, 2016 08:41 PM
ihf-350
Aug 21, 2015 07:52 AM
construct30
Exhaust Systems
May 30, 2015 07:00 AM
bigslurrp
Mar 22, 2004 11:26 PM
