1978 - 1996 Big Bronco
Argh, Water inside??
Old Dec 10, 2002 | 07:38 AM
Drilim's Avatar
Drilim
Hey all...
I woke up this morning to a few drops off water on the inside of my door panel. I know it comes in from the small "a" window, Along with all the dreaded wind noise. Is there anything i can do about this?? I was thinking about taking like a marine type silicone and just giving it a nice clear seal all the way around, But i dont want it to look tacky. If i buy all new stripping for it, How much am i looking at? Also, Is there anything else i can do for rattles on the inside of the truck, OR am i just gonna have to learn to live with it.
Thanks.
Old Dec 10, 2002 | 07:45 AM
fcarruth's Avatar
fcarruth
Autocrafters sells all door weather stripping etc... needed or JCW has some prety good buys as well. As far as the rattles etc... you can buy replacement poly bushings and what not and have heard on this forum that it makes a tremendous difference but a bit of work is involved.
Hope this helps,
Old Dec 10, 2002 | 10:04 AM
mweeps's Avatar
mweeps
Mine leaks at the Vent window too. I noticed the leak is between the glass and the metal frame. You can buy the black window glass sealant at Advance Auto Parts it is made by 3M. I haven't had time to fix mine yet the window has been replaced before and they did a poor job. The weatherstripping gets hung on frame when you ope the window and pulls loose from the door. It has stretched and I am going to have to replace the weatherstripping too. I will wait until spring so I can do it right and finally be able to put in my POlk door speakers. Also, try replacing hinge pins the door is probably loose and causing wind noise because you don't have good seal. Your door probably has play in it.
Old Dec 10, 2002 | 10:13 AM
JBronco's Avatar
JBronco
Mine does not leak, but I have always made it a practice in all my trucks not to open those windows (like not taking off the top, it does not leak, squeak, or rattle either).
Old Dec 10, 2002 | 12:12 PM
boobarrie's Avatar
boobarrie
the replacement rubber is about $45 per window, or you can get a new window for about $75.
My drivers window latch is all screwed up so I get BAD wind noise. I just wedged a piece of paper under it to shut it up for now.
have a merry one...:-X12
Old Dec 10, 2002 | 04:16 PM
Chaiyz's Avatar
Chaiyz
CR3999!
All Things Towing
Dec 29, 2015 06:55 PM
97Snake1668
15
Jul 22, 2015 11:35 PM
Krazee Matt
May 15, 2015 07:14 PM
old58
Nov 30, 2010 09:03 PM
guitar_199
1997 - 2003 F150
Oct 18, 2010 07:34 PM
