Deep Water servicing, preventative measures
Old May 13, 2015 | 05:06 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Had a massive flash flood here last night, had to rescue a friend before the waters got deep and on the way home the bayous and levees overflowed. Long story short, the X proved a hell of a lot tougher than I thought - had to crawl out the window and hang off the hood to flip the hubs in, was spinning the rear wheels against the current and massive amount of water. I am absolutely amazed that the door seals held and no water leaked inside, considering water was over the tires, and it's on a 4" and 35's. Fog and running light bulbs disintegrated, and the headlights have water sloshing around in them which I figured would happen. Not that big of a deal, just a PITA having to pull all the housings and bake them open for cleaning and re-sealing yet again.
Trying to get together an overall list of what I should start doing for preventative measures, or things to service or replace.
- anything with a zerk fitting gets greased to an inch of its life
- pull the sensors out of the front hubs and use Clay's fitting to grease the bearings
- pull the hubs off and disassemble, re-grease
- expecting to replace engine pulley's as they start to make noise
- bleed brakes if symptoms arise, however as of today's commute they're still stopping straight, with no pedal squish to indicate water intrustion in the lines.
- I'd say drain and replace the trans fluid, however the new trans is almost done so I'm not worried about it.
- drain, clean, refill the differentials
Anything else y'all can think of?
I was surprise this morning when I popped the hood, there wasn't a drop of water anywhere and zero signs of water making its way up the engine comparment. Air filter and fuse/relay boxes were completely dry. Also saw the water line on the radiator showing how high the water really was, I'm surprised the fan didn't shear or bend a blade.
Old May 13, 2015 | 05:30 PM
Bently_Coop's Avatar
Bently_Coop
Sounds like a good list to start with. While you are greasing the wheel bearings might be a good time to lube and grease the calipers.
Old May 13, 2015 | 06:22 PM
IMASAP's Avatar
IMASAP
I'd consider draining, and re-filling both diffs. Easy for water to get in the vent line if they haven't been extended.
Old May 13, 2015 | 10:35 PM
mecdac's Avatar
mecdac
Excellent advice so far, I'm guessing that the door seal mod was instrumental in keeping the passenger compartment dry.
Old May 13, 2015 | 10:53 PM
william_04_x's Avatar
william_04_x
I'd make sure a bunch of junk didn't get in the cooling stack, and other HXCs.
Old May 14, 2015 | 10:31 AM
Krazee Matt
Veteran: Navy
Appreciate the input guys! Looks like I'll be adding ABS sensors, or at least a thorough cleaning and overnight stay in a jar of dessicant packets to the current ones. Light on the dash is going bonkers.
Mark, I'd say that's the only reason the interior stayed dry. If I hadn't done the seal mod... yeesh.
Old May 14, 2015 | 02:38 PM
holeshotwalt's Avatar
holeshotwalt
Matt, glad to hear the X was more than up to the crisis!
Don't forget the transfer case oil change...
Old May 14, 2015 | 02:40 PM
holeshotwalt
And dialectric grease on all the lighting connectors and such.
Old May 15, 2015 | 07:14 PM
The2003Excursion's Avatar
The2003Excursion
ARB makes a vent that is made for deep water to put on differentials. Might want to add those.
http://store.arbusa.com/ARB-Differen...12-P22783.aspx
joegeds
17
Aug 13, 2014 12:19 AM
breeno
6.7L Power Stroke Diesel
199
Mar 3, 2014 12:20 AM
smashclash
Feb 23, 2012 06:34 PM
Thumper4995
27
Jun 16, 2006 01:52 PM
Miescha
Dec 12, 2005 07:47 AM
