Sponsored by: Auxito
pinging
Old Feb 8, 2007 | 10:25 AM
98F's Avatar
98F
pinging
I have 98 F-150 with a 184,000 miles on 4.6 Triton. It still has plenty of power and doesn't hardly use any oil and doesnt burn it either, but under hard acceleration it tends to give off a pinging noise like it detonating(preignition). Would this be caused by low grade fuel or would it be something else. I usually pu 87 octane in it. Thanx.
Old Feb 8, 2007 | 10:52 AM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE 98F.
Clean your MAF sensor. Use throttle body cleaner. Spray it down, let it dry. DO NOT TOUCH THE FILAMENT! Very delicate and breaks easily. Good luck!
Old Feb 8, 2007 | 11:09 AM
Johnny Langton's Avatar
Johnny Langton
It could be several things. MAF could be dirty,O2 sensors need replaced(unless done recently),and the fuel pump may be dying.
JL
Old Feb 8, 2007 | 12:05 PM
l-m tech's Avatar
l-m tech
its definitly a lean condition that is causeing the problem.maf or weak fuel delivery like stated will cause this problem.
Old Feb 8, 2007 | 12:18 PM
LxMan1's Avatar
LxMan1
How old is the fuel filter?
Old Feb 8, 2007 | 12:21 PM
Joe Finn's Avatar
Joe Finn
Can clogged EGR ports cause pinging from higher combustion chamber temps?
Old Feb 8, 2007 | 12:32 PM
98F's Avatar
98F
Thanx for all the info. Have no idea how old the fuel filter is. Had the truck for a year now but have been too busy with Army life to really do anything with it yet.
Old Feb 8, 2007 | 12:49 PM
Johnny Langton
No,the EEC knows the amount of EGR flow,and there are adders for ignition timing when there is EGR flow present. It's not much,but there are some EGR adders dependant on the truck's calibration strategy.
JL
93 mix 'n match
1997 - 2003 F150
Apr 5, 2010 05:57 PM
98range
1983 - 2012 Ranger & B-Series
Jun 30, 2007 07:23 PM
Mud Bone
32
Aug 19, 2006 10:49 AM
KennethKvittum
1997 - 2003 F150
Jul 9, 2006 02:20 PM
nolanc2
Modular V8 (4.6L, 5.4L)
Mar 4, 2003 09:36 PM
