Lost foot pedal control?
Old Feb 7, 2007 | 11:05 AM
ac1108's Avatar
ac1108
I have a friend with a 2003 F350 with a 7.3 and he says that after he uses his cruise control he no longer has control of his accelerator for roughly 3 minutes. He has been throwing parts at it and the lastest that the has purchase but yet to install is a throttle control sensor. Anyone have a clue what it could be? Any help would be appreciated. Thanks
Old Feb 7, 2007 | 11:15 AM
slc10844's Avatar
slc10844
What has he replaced?
Old Feb 7, 2007 | 08:44 PM
ac1108's Avatar
ac1108
What I know for sure is the CPS. He mentioned purchasing the throttle control and something else. I will find out for sure what else he bought for it.
Old Feb 7, 2007 | 09:49 PM
YellerMax's Avatar
YellerMax
So he's replaced one thing that isn't related to throttle position...
Sounds like a pedal assembly to me
Old Feb 7, 2007 | 10:07 PM
forddork's Avatar
forddork
have him check the idle validation switch tahts located in the pedal assembly. i had the same problem a while ago and when the throttle response would fade i would just hit the pedal a couple of times and it would usually come back in a couple of seconds. since then i have replaced the pedal assembly
Old Feb 8, 2007 | 08:15 AM
ponch37300's Avatar
ponch37300
The throttle position sensor is part of the pedal assymble. I got one at the stealership, surprisingly cheap(90 bucks) for the part. It's only three bolts and one wire connector, about 10 minutes to change.
SGorman13
Jun 6, 2014 05:20 PM
Kijutsu
2004 - 2008 F150
Oct 20, 2012 01:46 AM
Izzy351
23
Feb 14, 2008 01:55 PM
preppypyro
Jun 24, 2007 11:40 AM
Ferguson65
All Things Towing
Jan 25, 2007 05:18 PM
