Sponsored by: Real Truck
tick and pop
Old Feb 7, 2007 | 07:06 AM
usmc-superduty's Avatar
usmc-superduty
tick and pop
I started my truck this morning to warm up came back about 5min later got in put in gear there was a ticking sound and then POP! And now the coil over the spark plug is laying on the side and the spark plug blew out! What the heck happened?
Old Feb 7, 2007 | 07:31 AM
1buzzbait's Avatar
1buzzbait
yer gasser blew a spark plug out of the head-if ya don't have an extended warranty,the cheapest way to repair is to put an insert in the head
Old Feb 7, 2007 | 09:07 AM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
Is this a 5.4? My old f-150 w/ 5.4 did the same thing and thats when I got rid of it. They said it was a common problem in those engines because they only have a couple of threads to hold on to and that if they are not torqued right then they come blowing out. Best of luck getting this fix and I hope its not like mine where it was the very back one and they had to pull the engine to fix it.
Old Feb 7, 2007 | 09:26 AM
usmc-superduty
It's a 5.4L '01 F250. It was the drivers side second from rear plug. Blew the coil over plug apart. I'm thinking it was a stupid mistake on my part when I changed the plugs. I think I didn't have it torqued properly and it came loose. I got the plug back in and it seems secure. It runs with no strange noises. Code reader only says there is a problem with the ignition coil. NO KIDDING! It's in pieces. Having a mech check it this afternoon.
Old Feb 7, 2007 | 09:36 AM
biervergnugen's Avatar
biervergnugen
Did it damage anything on the way out?
Old Feb 7, 2007 | 09:38 AM
usmc-superduty
Just the coil over plug. broke the plastic housing. bought a new one from the stealer for $75 OUCH!
Old Feb 7, 2007 | 09:51 AM
JGRNAUT_7.3L
Ya sounds like you managed very well. When mine came out it striped all the threads and they were going to have to re-drill it to get a spark plug back in.
Old Feb 7, 2007 | 09:55 AM
usmc-superduty
I had a hard time getting the plugs in b/c my socket extension handle kept letting go of the spark plug socket (leaving it securely fastened to the sparkplug down deep in the hole!). I must have worked the plug loose trying to get the socket to let go and it finally worked it's way out. Lesson learned. At least I HOPE that is what happened. The mech is going to check the threads this afternoon. (fingers crossed)
Old Feb 7, 2007 | 10:15 AM
Jim59's Avatar
Jim59
Wow..... you are so lucky that it did not rip up those threads in the head. I believe Ford made a change to correct the problem .... I don't know what year they did so.
Anyway, many people here will tell you to be careful changing spark plugs on these V8 and V10 engines. Use only OEM plugs and a little anit-seeze, and some dielectic grease on the plug/boot area.
Make sure you have all the ratchet acessories you need to get to them, and then use a torque wrench.
And how the extension kept letting go of your spark plug socket ...... I believe there are "locking" ratchet extensions, I've been meaning to find one.
Old Feb 7, 2007 | 01:38 PM
themerritts's Avatar
themerritts
Exclamation blown plug
I am discouraged to see so many responses telling you to replace the head. I had this problem happen to me yesterday while driving on the freeway. I called Kragens, bought a new coil which has the boot included for $59.99. I also bought a spark plug for $2.49.
A simple search online gave me directions with pictures on how to change the coil. It involves unbolting the fuel injector rail which is a pain to realign, but the repair was simple and quick.
I have absolutely no mechanical experience prior to this beyond oil changes. Kragens has the healey kits for $14.99.
You don't need to replace the head, you don't need to buy a new engine, you simply just replace the boot, and if the threads are blown, the healey kit should fix that.
For Under $100, you can do it yourself with a difficulty rating of 4 out of 10.
Old Feb 7, 2007 | 02:00 PM
1buzzbait's Avatar
1buzzbait
a heli-coil will never hold in an aluminum head,and unless i'm blind (i am 50)- i didnt see anything bout replacing head,but having and insert installed instead!!
Old Feb 7, 2007 | 02:04 PM
redford's Avatar
redford
FTE Leadership Emeritus
No one told him to replace the head. However, if the threads are damaged you will need to put some sort of thread inset into the spark plug hole.
Old Feb 7, 2007 | 02:13 PM
sgthawkusmc's Avatar
sgthawkusmc
What's up Marine? A good trick for putting the plugs back in next time is using a piece of rubber fuel line. You can slip the end of the plug in it, lower it in the hole and thread it in. That way you'll know for sure it's threading right before you start torquing it down with a ratchet. It works well for getting it out too. Another good trick I remember from having a 5.4 is if you drop an o-ring or something else in the hole you can use a long funnel and a vacuum cleaner to get it out. I hope your threads do wind up being ok. Good luck.
Old Feb 7, 2007 | 02:17 PM
JGRNAUT_7.3L
Again as others have said I didn't see anybody telling him to replace the head or buy a new engine. I did say that they were going to have to pull my engine in my f-150 to re-drill the hole and thats just what they told me, I am no mechanic. Also I said thats when I sold mine and that was not referring to get rid of the truck or buy a new engine, that just happen to be when I was trying to sell the truck that it happened. Maybee you should actully read post before you come and try to accuse people of things that didn't happen.
Old Feb 7, 2007 | 03:36 PM
usmc-superduty
Just got back from the mechanic... In a rental car! Threads are stripped. They are going to do a reverse tap. A lot better than replacing the head that the dealership was going to do ($4000). I don't know about the healey kit. My mech recommended against it, unless someone thinks or knows different.
