leaking rear fuel tank
Old Feb 6, 2007 | 10:21 PM
tanglewood16137's Avatar
tanglewood16137
Guys where is best and cheapest place to get a new tank for rear of truck its a 1997 250 stroker.
Rod
Old Feb 6, 2007 | 10:57 PM
1stpwstk's Avatar
1stpwstk
..I had mine installed, I believe it was sourced @ Napa, price was nicer than Ford..
Old Feb 7, 2007 | 09:55 AM
fishmanndotcom's Avatar
fishmanndotcom
i repalced mine with a 33 galon bronco tank it is was practically brand new. upped the amount of fuel i can hold (38 to 52 gallons). it was prettty easy and i LOVE being able to go further betweeen stops
-cutts-
Old Feb 7, 2007 | 01:28 PM
ckal704's Avatar
ckal704
-cutts-
Was it from same year Bronco and did it interfere at all with things like the spare tire or receiver hitch. Forgive me if that is a little silly, but it is too cold to go outside right now and look at the rear tank configuration.
I like the idea of increased capacity. I get about 20mpg and that set up would get me about 1000 miles between fillups.
Old Feb 7, 2007 | 02:37 PM
tjbeggs's Avatar
tjbeggs
you need to move the spare tire to the bed. but thats the only side affect of the bronco tank. there is some minor fabrication that needs to be done also. mainly to the fuel sending unit if you use your original one. the bronco tank and pickup tank are the same price at napa from what I remember.
Old Feb 11, 2007 | 04:42 PM
Canoeracer's Avatar
Canoeracer
Based on the conversation here, I purchased a Bronco tank and installed it this weekend. I, like fishmanndotcom, love my new range. This was fairly simple change and took me about 4 hours from start to finish. I just wish there was a substitute for the front tank instead of the aftermarket 40 gallon tank for around $1,000.
Old Feb 12, 2007 | 09:04 PM
tanglewood16137
ok i just bought a used tank was in truck for 4 months with sending unit for 40 bucks i hope it will work. from a 81 to 86 bronco
Rod
Old Feb 12, 2007 | 10:50 PM
fishmanndotcom
SHWEET
i hope you did the modified filler neck!
-cutts-
Old Feb 13, 2007 | 06:36 AM
tanglewood16137
how do you do filler neck mod i have yet to pick up tank so i still have time to do it.
Rod
Old Feb 13, 2007 | 07:31 AM
F350_Hauler's Avatar
F350_Hauler
Is the bronco tank you're talking about the plastic one?
Old Feb 13, 2007 | 08:55 PM
sparky30_06's Avatar
sparky30_06
what mods to the sender do you have to do?? what if you get one with a sender already in to??
Old Feb 13, 2007 | 09:18 PM
Canoeracer's Avatar
Canoeracer
I just went to the junk yard and asked for a '93-'96 Bronco tank. I guess I got lucky because the one they brought out was the metal one, I didn't know the difference at the time. It has the larger opening. The tank is 8" deeper than the original and all I did was add about 8" of tube with a clamp on the pick up tube and cut the sending unit rod and silver soldered 8"s onto the length. I did not do the filler tube mod but when I went to fill it the first time I only put in 10 gals to make sure I had it right. the next day I filled it up all the way and never had a problem like I used to with the old one, just lucky I guess.
