injector replacement question
Old Feb 6, 2007 | 06:12 PM
gomfrddy's Avatar
gomfrddy
how long should it take for the truck to start after replacing one injector? also can I start the truck with the valve cover off?
thanks!
Old Feb 6, 2007 | 06:50 PM
tjbeggs's Avatar
tjbeggs
if you refill the high pressure oil reservior it may take about 1 or two minutes worth of cranking. but only crank for 30 seconds at a time max!! also yes you can start the truck with the valve cover off. the oil will not squirt.
Old Feb 6, 2007 | 07:01 PM
gomfrddy's Avatar
gomfrddy
where is the high oil pres. reservoir? do you have a pic?
Old Feb 6, 2007 | 07:21 PM
gomfrddy's Avatar
gomfrddy
Old Feb 7, 2007 | 10:18 AM
tjbeggs's Avatar
tjbeggs
the reservior is under the plastic engine cover. top front of the motor between the alt and a/c compressor. it is an aluminum housing with a allen head or 1/4 inch square drive plug in the top on the drivers side. the housing is about 2 inch by 6 inch. directly behind the housing will be the fuel filter housing.
Old Feb 7, 2007 | 04:49 PM
ForemanES's Avatar
ForemanES
It was funny when I did mine I just purged the cylinders 2 different times for 30 seconds with the 4 plugs disconnected with the starter after I got most of the oil/fuel out of back cylinders. Then checked the hpop res and it was still full. When I was all done double checking everything I jumped in and it started within 10 seconds.
pawayne63
Nov 8, 2016 07:31 PM
Azfordracing
Feb 23, 2015 11:27 AM
txweslawyer
Mar 5, 2014 10:45 PM
daw00l
Sep 9, 2009 11:20 PM
saubouin
2004 - 2008 F150
Dec 28, 2007 05:22 PM
