View Poll Results: Factory Slider or solid rear glass?
Factory Slider
73.33%
Solid Rear Window
26.67%
Should I install Factory slider with scratches?
20.00%
Should I install Solid Rear glass with no noticeable scratches?
6.67%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Factory Slider or Solid Rear Glass?
Old Feb 7, 2007 | 11:43 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The factory slider is the only way to go, and there are several products available to remove scratches from window glass. One is Jewelers Rouge.
Wouldnt have thought of that. It might not remove the deepest ones, but it would definately lighten them up and remove most of them. Thanks.
Old Feb 7, 2007 | 12:00 PM
81-F-150-Explorer
Originally Posted by Americanmadeford
MY factory slider leaks. Im trying to plug it, but Im not having much luck.
They all leak, you just might not see it on most. They have drain holes at the bottom of the channel. Make sure these are not plugged up so the water can drain.
I'm replacing the dealer aftermarket slider in my truck now for the factory one. The outside seal was bad, and the window didnt fit tight enough. It didnt leak much, and not in the rain. Only at the car washes. Would make the X-wife cringe when she got sprayed.
That and I got a great deal on two windows. The slider, a regular back glass tinted, and two good window seals for the price of just the one seal alone if bought new.
One BIG down side to the slider is they can be open from the outside! (or mine can) Sunday I locked my keys in my truck and easily popped the slider open using a pocket knife!
Unfourtunatley i had wire wrapped around the latch keeping the windows shut and had to break the vent window to get in
If they want in bad enough, yes, they will break a window. Or break the vent latch.
newfordy
2009 - 2014 F150
Jul 12, 2015 01:09 PM
JKNW
Nov 18, 2014 05:35 PM
madpogue
Jul 19, 2014 09:58 PM
SuperDuty93
21
Feb 20, 2013 09:14 PM
caspermj
15
Jan 24, 2009 10:22 AM
