I usually hang out in the 73-79 forum but need info on a big bronco. My sister-in-law moved back home from WA last week and showed up in a nice big bronco. Kinda funny since she left in a Festiva.
I forgot what year it was (86 0r 96) but I know it's an XLT and it has a 351 with a sticker on the valve cover that says Winsor Ontario. I assume it's a 351w. I hope this is enough to go off of.
The problem is that her cruise doesn't work. I'd like to fix it for her but I'm wondering what all I should be checking. I know to check the fuese, wiring and vacuum hoses, but what else?
This thing is way more complicated than my 78, so any help would be great.
Most common problem with the Cruise Control is the servo going out. Its located right next to the master cynlinder. I don't know how to check it...just that I had to replace it once to get my cruise control working again.
The buttons in the horn pad have resistors attached to them; there are 2 relays buried in the dash or hanging in the engine compartment, there are a few vacuum hoses, one of which goes thru the firewall to the brake pedal arm; the servo's cable clips on top of the accelerator cable at the throttle; the computer is mounted to the bottom of the dash above the gas pedal with 2 connectors side-by-side; and the vehicle speed sensor (VSS) is on the speedo cable somewhere, but most likely at the bottom end where it goes into the transfer case. The VSS and the vacuum switch on the brake pedal are the most common problems.
Does anybody know what might make the cruise control in my 90 not hold speeds well on inclines? Also, when I push the button to accelerate, it does, but very slowly. Not big problems, but I'd fix them if it was an easy adjustment or something.
>something.
It's probably a fuel economy thing with the computer. It's programed to speed up slowly to avoid down shifting.
When you drive, you PREPARE for a hill by speeding up before you get there. The cruise can't see the road so it REACTS to the hill. Unfortunately, by then it's too late. You've already lost momentum.
It's because your engine loses vacuum as the throttle opens, and it's engine vacuum that opens the throttle. Catch 22. You probably have a vacuum leak somewhere in the cruise system or on the engine, or the engine is just wearing out. Order an $8 vacuum gauge from JCW and you can watch it. I have one on my truck, but I also swapped to the later electric servo so I'm not dependent on vacuum for cruise any more.
The engine has relatively low miles and runs good, I think it is the vacuum as I also have the problem of the ac vents switching to defrost on hard acceleration. One day I will check all the hoses, it's not really a pressing issue.
The vacuum reservoir doesn't actually increase the vacuum pressure, but it allows more thing to work off vacuum even when the engine isn't producing much. The fact that your A/C is changing confirms that it's a vacuum issue, but doesn't eliminate the engine as the problem. What's the manifold vacuum at idle?
http://www.users.bigpond.com/ergoff/vac1.htm
