Parking lights not working
Old Feb 6, 2007 | 10:51 AM
mmacsek's Avatar
mmacsek
I was given a 77 F 150 from my uncle last year and finally have time to work on it. The truck sat for a little while so.... All the lights work except the parking lights, front. The side lights on the front fender work so I'm ruling out the switch. The turn signals work fine and bulbs are new. Any ideas where to look? Thanks Matt
Old Feb 6, 2007 | 12:45 PM
Mil1ion's Avatar
Mil1ion
Broken (BROWN) wire in the harness ?
Old Feb 6, 2007 | 12:46 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Check the bulb sockets, you should have 12V to the sockets brown wire with the parking lamps on.
If you do have 12 volts in the brown wire at the sockets, make sure that power is goint through the apropriate socket terminal inside the socket, if not replace the sockets.
If you do not have 12V in the brown wire leading to the sockets, check the two front parking lamps. they are on the same circut. If you got power there, then it could be a problem with the wiring between the side markers and front lamps.
However, I suspect a problem with the sockets themselves.
Hope this helps....
Old Feb 6, 2007 | 12:56 PM
Mil1ion's Avatar
Mil1ion
If he has power to the side marker lights then I presume the problem will between them and the lights in the Combo turn signal/Marker lights socket.
Old Feb 7, 2007 | 08:50 AM
mmacsek's Avatar
mmacsek
Thanks for the responses. I will check out your suggestions. Matt
wrd0225
Sep 30, 2014 10:53 PM
troupstree
21
Jun 22, 2014 06:48 AM
lemonshindig
Mar 1, 2010 07:50 PM
Matt300ZXT
Dec 26, 2008 07:47 PM
mdmccool
Electrical Systems/Wiring
Dec 21, 2005 05:27 PM
